2005 vrod crank no start. Have checked all wire grounds and positive through ECU TSM and ignition and dash all are good no check engine light on ignition position on the switch check engine light comes on when it's on the accessory position there's no ground at the system relay There Is Power all the fuses are good I don't know if I need to put a new ECM in if I do can it be plugged in and have the bike run? If I unplug the ECM from the wiring harness the bike seems to act exactly the same no run with it plugged in.Help!!!
I have the factory manual
