Frank
I am the original owner. Bike has 10,200 miles on it. It was built as a 1430 since it had 15 miles on it.
The last time the bike was on the track (which was more than 8 years ago), it ran a 10.701 @126 with a 230lb novice rider on board (me). A proper sized and talented rider should easily take the bike into the 9’s. The bike is now at least 20-30lbs lighter with the latest updates.
The bike typically dynos (varies between machines and condition), between 145-155rwhp and always over 100ftlb of torque on 91-93 octane pump gas (with the crappy ethanol in it).
The paint was done by Ghost Mule in OH using House of Kolors Black Cherry with Brandywine Flames.
I would give the paint, powder-coat and chrome all 8/10. The Engine would get a 10/10.
Bike was completely refreshed less than 500 miles ago. Changes/upgrades that were done at that time:
New HD 2012 NRS Anniversary Version Wheels
New HD Michelin Tires
New HD Brake Rotors
New Rebel Gears 21-Tooth Front Sprocket (with rear is same a 28-tooth belt setup)
New Custom Rebel Gears 54-Tooth Rear Sprocket
New Custom Billet Rear Drive Adapter to Match Wheels and Sprocket (w/bearing)
530 Nickel Plated Chain
New Holymoto Single Piece Tool Steel Throttle Body Shafts
New Jones Stage 3 Cams (260/[email protected] .050", .500"/.460")((heads and cam covers clearanced)
New ARP High Tensile Strength Cam Cap Bolts
Progressive 412 12-1/2” Black Shocks
Updated Tune for New Cams
New Second Set of Front (22) and Rear (53) Sprockets for an equivalent 30-Tooth Belt Setup
Besides the updates mentioned above, the engine includes:
Stock cases bored and clearanced for 108mm (4.250”) Sleeves, 6mm Stroke
Falicon 6mm Stroker Re-weld/Balanced Crank
4.250” Advanced Sleeves
CP Pistons and Rings (12:1)
Carrillo H-Beam Rods
Vreeland Coated Rod and Crank Bearings
Destroyer Injectors
Destroyer 58mm Throttle Body
58mm Bored Stock Stacks
Destroyer Intake Boots
Black HD Heads, CNC Ported by Vance and Hines with 1mm Oversized Valves
Diamond Heads Cutting Process
Beehive Valve Springs
10mm ARP Head Studs
Doherty Steel Crank Brace
10mm ARP Crank Studs
V&H Straight Cut Second Gear
V&H Solid Shifter Fork Shaft
’08 HD Slipper Clutch w/ Red Barrnett Springs
’09 HD Oil Pump
Complete Set of HD Chrome Engine Covers
Polished Stainless Steel Bolts
Chassis, performance and cosmetic modifications:
EarthX ETX36C Lithium Battery (320CCA)
Optimate Lithium Battery Maintainer
D&D Fat Cat Exhaust w/18mm Bungs
Walbro High Volume Fuel Pump
HD Race Tuner (mated to current ECU)
Complete Air-box Trim
HD IAT Sensor Relocate
Pingel Premium Electric Over Air Shifter
Pingel Programmable Electronic Kill Module
Pingel Bar Mounted Kill Switch Tether
Customized Black Powder-coated Swingarm/Airtank (when equipped)
Pingel Air Gauge and Valve Mounted on Swingarm
Onboard Air Compressor for Shifter Tank and Air-ride
Horn Mounted Switches for Compressor, Air-ride (when equipped) and Shift Enable
Daytona Adjustable Hydraulic Steering Dampener and Billet Mount
Custom Chrome Rear Shock Drag Peg Mounts
V-Gauge Instrument Cluster
HD Chrome Coolant Hose Cover
Arlen Ness Front, Rear and Drag Twister Pegs
Arlen Ness Twister Grips
HD Black Hand Levers (Harley)
Black Powder-coated NRS Bars
Black Powder-coated Riser/Instrument Cluster
Black Powder-coated Triple Trees
Black Powder-coated Front Shock Lowers
Black Diamond Braided Stainless Steel Brake, Clutch and Throttle Lines
Customized black powder-coated upper belt guard
Progressive 1” Lowering Front Fork Springs
Saddleman Seat
Heavycycles ‘V’ Stage 2 LED Taillight
LED Turn Signal Mirrors (inverted) (Kuryakyn)
Custom Illuminated Black Poweder-coated Right Side License Plate Mount
Customized Rifle Roadster Fairing (w/dark smoked bubble windshield)
Custom Black Powder-coated Billet Headlight and Fairing Mounts
HD Security System with Sounder and Back-up Battery
HD Frame Bag
HD Chrome Front Axle Bolt Covers
HD Black Rear Axle Covers
The V-Gauge which is included on this bike is a work of art and functionality in and of itself. It not only duplicates the Tach, Speedometer, Tripmeter and Odometer functions, it also provides Gear Position, Air Temp, Engine Temp, current MPG, Average MPG, Range, Shift light, Shift Point, compete ¼” mile drag race function (which gives speed, gear and RPM at 60’, and other distances) and lots more.
Asking $14000
'04 1300
This bike is a legend in this community (as is the seller), and an extremely well-sorted custom BB. Whoever lands this is getting a hell of a bike.
Asatruar
