I take my v rod for a spin stop for a short time and when I go back to it it will turn over but won't start I've changed the battery in the alarm fob but it makes no difference. I'm looking for some pointers please
The Hawk
Any codes? Also, has the IAT sensor been moved from down between the cylinders up to the air box?
Sent from my LM-G820 using Tapatalk
Not sure how would a get the codes to show is it a sequence. I picked the bike up in my van rolled it off the following morning and it started on the button as normal.
Like mentioned above, is the IAT sensor between the cylinders or is it in the top of the airbox?
2002 models had the problem along with a TSB and a relocation kit for the fix
The Hawk
To get codes press and hold the button on the speedometer until the code screen comes up, then use the button to cycle through the sections, write down the codes and hold down the button to clear the codes.
