180mm mounting kit with homemade fender bracket.
I purchased this for the additional fender brackets (not pictured, not included) that were with it and looked to be very similar to the normal 240mm brackets. Seller stated the entirety came off an ‘06 DX though really don’t know how the brackets I kept had anything to do with it. Appears someone custom fabricated a set of the 180mm brackets that mount to the fender and are seen attached still in the picture.
What is pictured is what is included; no additional brackets or bolts.
To mount on a 180mm, you’ll need any missing bolts and I assume a set of the small shock support brackets (available solo from a seller on eBay) though it’s possible this may have been made long enough to fit to the shock if you give it a try first.
$125 OBO shipped within the 48.
Harley OEM hardware kit with install instructions in the “more info” section. You can see there the comparisons from the OEM kit to this with the homemade bracket.
https://serviceinfo.harley-davidson.com/sip/service/document/118929?locale=en_US
