I have the 16ga SE pipes on my bike now. I am new to the exhaust change, but do i need stock header pipes in order to install the CFR pipe? I have heard or been told the 16ga SE is a complete system and in order to install the CFR i need the stock header pipes as the CFR is a slip-on.
I thought the 16ga was a slip-on as well...little confused. If anyone can help that would be great!
16 gauge keeps your pipes coming out of your heads. New crossover/ 2nd volume and third volume (actual barrels). You should be good to go on the swap, from what I understand the CFR is 2nd volume back.
Nate
:them: I went from 16 ga to CFR. straight swap.
