:confused: Have seen that alot of people have the 16 ga pipes.Are you'al runing with the baffel plate in or out? Just had them installed. any info would help thanks.:biker:
Mine is in. Taking it out requires a retune, I believe. Give them a little time. You'll grow to like them.
Moderator
Leave the baffel in...Your bike will run lean if you run without the baffel. Also will screw up your back pressure on your bike
