Figured out what I'm doing for Stage 2. Anyone want to guess numbers before Dyno?
Delete (can someone tell me how to do this? new to message boards)
It is currently sitting topless with a k&n air filter(custom airbox cover with better air vents, matching fenders that dont matter for this reply but figured id mention)why not do an upgrade? just make sure whoever does it knows what they are doing, and get it tuned by a competent tuner. And I know plenty of people will try to talk you out of it, but if you have the cash yeah id do all the mods plus a V&H or Fitzgerald ground pounder or at least a dan moto pipe. these bikes need much bigger pipes than stock.
I sent an email seeing what they suggest.Oh, and if you can, call Jones cams and buy a set of his if he still has cores, they have a wider base circle and are supposed to be easier on the valve train. They definitely look to be high quality, I just recently got a set of STG.III cams they look great and are made from billet steel instead of cast like the factory cores.
deleteOh, and if you can, call Jones cams and buy a set of his if he still has cores, they have a wider base circle and are supposed to be easier on the valve train. They definitely look to be high quality, I just recently got a set of STG.III cams they look great and are made from billet steel instead of cast like the factory cores.
