82in. 2002 VRSCA. 3,875 miles on bike. 400 miles on engine.
4.285 bore, new CP pistons, actual 12.1:1 compression ratio. ported heads, oversize valves, new guides and valve job, Fererra spring and retainer kit, SE stage II cam kit, 12mm head studs, case studs, main and rod bearings, balanced crank, modified shift drum, modified primary chain tensioner, plugged oil jets. Barnett clutch springs. Supertrapp. 150hp 98tq
New powdercoat on frame with mounts for H-D mid controls welded to frame on left side, Kosman Buell wheel and Brembo brake kit. Kosman chainn drive kit. Kosman mid control kit. new battery.
$10.995.
$10.995.
