If DTT has idle set accordingly...
Warm engine, turn idle stop screw ( back right side of throttle body vertical screw ) out to lower RPM, turn off kill switch let IAC finish movement, kill power. Turn power back on, verify TPS voltage adjust as needed ( at the sensor ) Start bike, check idle.
