561 - 580 of 628 Posts
all or nothing
Discussion Starter · #562 ·
I thought you have a slipper clutch with four springs?
I had SE slipper while bellow 240rwhp, then it started to slip both ways.
all or nothing
Discussion Starter · #563 ·
Deja-vu:D
all or nothing
Discussion Starter · #564 ·
Meanwhile in Finland.
all or nothing
Discussion Starter · #565 ·
A piece by piece ahead. Modified GT2860R and Tial 1.1bar waste gate ready to install.
all or nothing
Discussion Starter · #566 ·
all or nothing
Discussion Starter · #568 ·
...have to admid, bought an airhead, heritage softail classic 103cid 2007....but just for a quick business :D
VRSC est -03
Nonsens you crazy Finne, yourè ending up with a turbo`d S&S 143 ci..... :)
all or nothing
Discussion Starter · #570 ·
Made a new "collector" from AISI316
Front and Rear cylinders are separatet till a turbine to prevent exhaust pressure running from a primary to another. (pumping losses)
The 55 mm diameter primaries are straight directed to the turbine for a linear flow.
The part was a nightmare for beginner TIG welder (me). Will cover it with a chromed heat sheld.
all or nothing
Discussion Starter · #571 ·
Some more self made stainless stuff,
charge pipes are 2½" diameter.
Will the brace mount down to the frame? Are you rigid mounting them or will you have rubber shock grommets ? If your charge pipes are 2 1/2 inches, where are you putting in the step, isn't the stock diameter 1 3/4 or 1 7/8" ? Fabulous work ! Thank you for sharing & keeping us all motivated !
Autobanmod
From personal experience I can advise you that:
the tack weld does not look like it will last very long
and you don't want any welding droplets fall into the turbine, so polishing inside is more important than a shiny outside
all or nothing
Discussion Starter · #574 ·
Thanks, I will re-melt it.
all or nothing
Discussion Starter · #575 ·
No rubbers, straight to the stock mounting place. The primaties are in four step ending to 55mm.
all or nothing
Discussion Starter · #576 ·
Bassani Xhaust, "power you can feel" :D
Turbo cooling lines and IC cooling fans are still missing.
Otherwise it is done.
Autobanmod
A Piece of art, congratulations.
I'm wondering if the exhaust wastegate makes nasty noise when it opens? Shouldn't it be connected to the exhaust line behind the Turbo / before the muffler?
all or nothing
Discussion Starter · #579 ·
Thanks Poppa and J-D
It will be an audional boost gauge to know when all are in :D
