2" of dangling death
1250 kit, cp pistons, destroyer crank and TB question. whos running this setup and what cams are you useing or planning to use?
what would work best?
Tyson, I do not think you will see these engines built until winter. I know Lonnie is doing this build with a little :stilpoke: Destroyer crank as well as a couple others. The Megacycle .480 or the Jones cams seem to be the choice or dreams of most.
I will be doing the 1250 bore, CP piston, stock length rod, 1/4" stroke build this winter. I will most likely use the Mike Jones .500 cams from the forum store with his spring kit.
Insane inda membrane
I'm doing a similar setup with the Destroyer Crank. I think Lonnie and I are building pretty much the same thing. I'm going to use a similar cam to Ken's.
"A" is the only way
I ran and will be running the mega cycle cams, but I would of probably used mikes if they would of been out when I was buying cams
