1 - 20 of 31 Posts
Sharks-Parts
Greetings -
what would be involved to take an 1130cc engine and make it a 1250cc engine?
swap jugs and pistons?
thanks
You have to bore the cases, from my understanding an 1130 to 1250 is all the screaming eagle big bore kit they used to make was.
No, I wish it was that easy. The cases have to be split so they can be bored to accept the 1250 cylinders larger diameter spigots. It ends up being close to a $5000 job including the 1250 kit for maybe a six horsepower gain. I looked at doing it and gave it a pass. You can get as large a power gain from intake, exhaust (if you choose the exhaust system carefully, not all work that well) and re-mapping the ECM.
There is this loon ball in my town with a stock displacement D that has had the heads ported, some sort of aftermarket cam, drilled out air box lid, K&N and Supertrapp slip ons and a dyno re-map. That thing is F-ing fast, but it gets 28 mpg if that.
AIM Bagger Edition
Weak a$$ intake cams as well. When you install the HD 1250 kit you use the same stock exhaust cams.
Sharkey if you have a customer considering this please try and talk him out of it and save him the disappointment.
I could have cried way back when I did mine and it made no difference at all.
I would say if you are going to do motorwork, picking up a big bore if you can find one is a good start, but deffinatley don't stop at a 1250, go bigger.
durata membro
You are better off w a set of pistons,a Destroyer crank and the Harley performance cams.
Probably give it close to 140hp to the rear out of 1177cc's.
28mpg is great fuel mileage for a performance vehicle.I took a car that used to get 37mpg,played w the exhaust,intake and the ecm,it now gets less than 20,but the little V-6 wipps the V-8's.
Waste of time. Get a Vmax or just do what the above mentioned.
Sharks-Parts
he has stealth nitrous and was hoping there was a quick switch from 1130 to 1250....
Thanks for all the advice here...
1402 or go home
Eh, tell him that when he blows the engine up he can rebuild it with a big bore kit. :chainsaw:
Insane inda membrane
you can buy a new 1250 from hd for about 6k almost cheaper than modifying the 1130 and you would have a spare motor.. if you are going to the expense of pulling a 1130 motor apart a 1450 is probably the best bang for the buck if you get the welded stroker instead of the billet crank..
1 - 20 of 31 Posts
