Wick said:
Ok so they will bolt on. I am still awaiting my bike but have a set of Rinehart Staggered, Sert, K&N filter sitting at the dealer waiting to be fitted when it arrives. Read elswhere on this site of an AW owner who brought the same pipes only to have the dealer ring him and tell him they wouldnt fit??
several exhausts for our Vrods are SLIP ONS...meaning the stock HEADPIPES(two) remain intact....the 02 sensors on the 08s are within the two stock headpipes..
that being said,you CAN use MANY of the exhausts on your 08 from previous model yrs and make them physically fit.....(CFR,thunderheader to name two)..I bought myself a used thunderheader off a 04 vrod...the THs are a slip on 2-1 setup,so the 02 remain intact and I will simply Make up a new bracket for my wider frame....
you need to take into account the WIDER FRAME of the 07 and newer models,which will have a slightly different bracket mount for wide frame.
your biggest issue with 08 models will be a fuel controller....this is due to fact the 08s are a 1250 & have the 02 sensors which need a different controller then previous model yrs...DOBECK has two available at the moment and I think the SERT from HD is also out...no others out as of this thread though.
you mentioned RINY 2-2 staggereds....those pipes are a FULL SYSTEM and would NOT work on your 08....they do not have BUNGS for the 02 sensors....now,there is no reason you could not have bungs welded into them,especially if you have those pipes already and like them...
Im quite sure you MIGHT be able to go around the 02 sensors IF you use a GEN2 dobeck which Ive heard eliminates the use of 02 sensors altogether...but you would need to talk to DOBECK about their GEN2 first....IF the GEN 2 dobeck basically eliminates the 02s,then I see no reason that you couldnt use your 2-2 staggereds as is...without 02 bungs.
hope this helps
Dan
