1 - 3 of 3 Posts
Back in Black
Greenville SC
engine built by famous lonnie (smoothrod)
bored stroked port polished heads. Electric shifter. throttle down no clutch don't let up and computer shifts, or use a button. saddlebags that lock and come off with 2 bolts. progreesive shocks. custom airbox. raked. 26 tooth pulley. exhaust. Daytona twin tec computer. Muscle wheels. Nos, note bike will come with 2 unfilled bottles. NO you can not try the nos out. Yes it's there and works. I may have used it 10 times. through out the years I spent close to 15 thousand on the bike. a scrape on one bag few minor paint blimish rims good use polishing all nothing most people will see. much much more see below. more recent and better photos coming
led lights opt 7 50
sprocket cover off 2012 bike powder coated 50
wheels off of a vrod muscle 500
electric shifter pingel fully electric auto rpm set no clutch 900
pulley front 26 tooth sprocket fitzgerald motorsports 240
computer daytona twin tec 770
front fender custom franklin only one made 125
horn relocated so not seen 5
cam covers custom made cam covers 10
airbox custom franklin 300
exhaust rinehart 2 to 1 700
exhaust handmade baffle 10
shocks Progressive 440 275
springs front lowering springs 100
clutch slipper clutch 200
raked trees raked 2 degrees different year trees powder coated 125
headlight from r model v-rod 100
hid headlight hid nation lifetime warranty 40
mirrors HD tribal mirrors 80
seat saddleman 200
seat Gel & memory foam added 45
Radiator spoiler ebay 100
covers axle & swing arm custom covers 80
covers custom clutch and derby covers 120
saddlebags from a dyna with hand made brackets 600
shift linkage Joker shift linkage 50
turn signals led 60
kickstand modified for lower bike 25
pegs performance machine 40
grips performance machine 80
taillight custom dynamics 40
handlebars drag bars 50
air filter screaming eagle washable 50
covers fork tube covers 25
covers brake and cluch master cylinder covers 35
speedo r model speddo cluster 200
speedo cover ghost rider 60
radiato grill vrod covers 25
gauge revitupcycles fuel pressure gauge 40
bolts stainless steel bolts 80
seat cowl custome rear seat cowl 200
frame covers fiberglass german made 100
brake pads ebc brake pads front and rear 60
nitrous nitrous 40 hp with purge computer operated 225
engine bace griddle on bottom end of engine 200
studs ARP 10mm Drop In Head Stud Kit 150
engine 12 to 1 cp pistons 450
engine destroyer crank shaft for desroyer drag bike 300
engine stage II 492 lift cams 400
engine heads port polished 1500
engine bored 700
engine rods 100
engine gaskets, assembly, tuning, oil pump, etc 2000
603471
603472
603473
603474
603475
603476
1 - 3 of 3 Posts
