1 - 18 of 18 Posts
Fitzy - 1302
07 AW Wheel set w/240 rear
I have got an 07 AW wheel set that I would like to sell. These are the slotted machine polished wheels with the 240 rear. Complete with tires, brake disc's, pulley, hardware, and belt. About 2k miles on them and there in great shape. 90% tread on rear. Would be a good start to convert to a 240. $875.00 + shipping. Each wheel will be carefully shipped in its own box with some of the components. Each box will weigh 60lbs, 120lbs all together. The wheels are in my gallery on the bike.
1130cc.comaholic
so I'm guessing the 240 will fit in the stock swingarm? do you know what would be needed for the switch from stock 180 to this? I'm only guessing but would I need a new pulley, spacers, etc.?
I'm gonna do a search :bolt
I have just ordered the parts for this conversion. For my 04 all I need is the AW wheels (ordered from Zanottis) skinny belt (again Zanottis) and the rear pulley to be machined down (VMOD)
Hope this helps
Cheers,
Batts
Fitzy - 1302
New price.......
I would be inter4ested in the front wheel if you are willing to break up the set.
PM me with a price if you are interested.
Fitzy - 1302
wicked said:
New price.......
I see my message didn't go thru.
New price is $875.00
(.)(.)Modster(.)(.)
Can these be machine cut by Gorby's?
Fitzy - 1302
Not sure. You would have to check with him.
deleted
Fitzy - 1302
Discussion Starter · #12 ·
As of now I have sold the front wheel to RustyG. I am selling the rear -
240 wheel w/tire (90%), pulley, belt, and rotor for $575 + shipping!
Fitzy - 1302
Discussion Starter · #14 ·
Front wheel sold to rustyg, thanks!
PM sent
You can use the rear wheel for the mod on an older bike like I did on my 2003 A with the old spacers and everything! You just need to mod your rear pulley and order the narrow screamin eagle belt. (a few other tweaks of course)
I have received my new Front wheel from Ken and it was in perfect shape. Looks almost brand new and well packaged.
I have it installed on my bike. Real simple install. remove Brake Calipers, remove axle, remove wheel. INstall new wheel and reinstall brake calipers.
Install went perfectly no spacer adjustments or anything like that. Wheel was from a '07 AW. My bike is an '07 VRSCX. Perfect match. Bolt patterns for the rotors are different but this was not an issue.
1 - 18 of 18 Posts
