Fear The Reaper
Does anyone know how to put this freakin alarm in transport mode. I did what the little card said and nothing happens. If anyone knows this solution please share.
The card is for arm and disarm, when the fob is not present or no battery
To set transport mode
Turn ignition to Ignition have fob present, swith kill switch off run off
press both inticators at the same time they should flash once
turn ignition to off indicators should flash 3 times.
your set
to eixt
With fob have ignition and kill switch set to run
Cheers
Fear The Reaper
:cheers: Thank you much. Off to Sturgis and want this mode so it doesn't go off the whole 1300 miles and drain my battery.:cheers:
fire up !
your set
to eixt
Cheers
Shed that's strange, i have a (international model) 07 (DX) too and the transport mode procedure is indeed printed on my little card but it reads otherwise for the 'to arm' part :
to arm :
- turn key ON then run switch to OFF
- turn key to ACC
- (quickly) press both indicator buttons, indicators will flash once
- turn key to OFF, indicators will flash 3 times
to disarm : with fob present turn key to IGN + run switch to RUN
just tested it and it works like my card says; when i do the arming with 'turn key to IGN' iso 'turn key to ACC' all indicators start flashing permanently (as intended)
grtz
