1 - 20 of 21 Posts
Just want to hear if this happens with a healthy engine, bike has 1,400 mi. oil changed at 1K, synth oil used in the change. never noticed before,just since the 1K service. but at startup, it puffs some smoke from both muffs, just for 5-7 seconds, and only if its been sitting for hours, or over night. wont do it at any other time.Oil level is ,and has been fine, It isnt coolant, dissipates quickly, and doesnt smell sweet, or vapory. Any thoughts? experiences to share? thanks, Geezer.
What synthetic oil did you go with? Most likely just moisture from the exhaust. You should be able to use your nose and tell the difference in coolant, oil or condensation.
It smells like exhaust, not strongly of oil. not like a 2 stroke, (compared it with my daughters stella scooter) The invoice shows the oil as "syn3/chrome". Chrome for the filter I guess,It didnt puff yesterday, havnt looked today. it could well be moisture, its been hugely humid here in Milwaukee lately,though drier yesterday.I'm concerned because I'm going on a trip to S. Dakota soon, and dont want to have problem while out. I really appreciate the help too! Thanks, Geezer
Thread Killer
i wouldn't worry too much. More than likely just condensation build up in the exhaust!!
I will have to agree, the oil level hasnt changed, the coolant level is right on, perhaps i have a late bloomer in seating the rings, though after 1400 mi. that should have happened. (its probably all of the fire n' speed waiting to get out)
Scott
But you said it lingers...that means an actual substance in the smoke. Not water...that evaporates to quickly for it to linger. Where did you get your gas that week?
Same as always, a BP station nearby, but that doesnt mean something isnt in the fuel, it needs a fill anyway, so i'll try a different place and see if that changes anything.Thanks, didnt think of that one,,,Edit: Just a thought, before the 1 K service the bike was stalling in tight right turns, one stall threw me over, and the bike went down thankfully very slowly (those hours in the gym do pay off.) there may be some oil in the airbox, so I will have a look, and let you know what I find.
Edit: update, No oil in the airbox, nice and shiney clean. fuel from different station in the tank, smoke barely noticable today. An odd bike to be sure.So far, so good, we'll see when I head over to Deadwood this month.
Nucking Futs
While you're riding around trying different fuels, you should at least cruise the engine in the 4000rpm or up territory for 20-30 min to ensure you burn off whatever condensation may be in the engine. Too many short trips where the engine never fully warms up will cause you to experience some puffs on startup.:2cents:
Discussion Starter · #11 ·
Thanks, had not considered that.
Discussion Starter · #12 ·
Well, i rode the thing down to Kentucky, and it still puffed, and lost 8 oz. of oil going back home. no obvious leaks, no lights came on, so it has an appt. W/ the dealer weds. so we'll see .
Keep us posted
Discussion Starter · #14 ·
I just spoke to the service writer, he said that they had to contact the MoCo for help, it seems according to the Oracle on Capitol Drive, that my engine has not yet broken in. that there has been an increase in the number of engines having this problem, due to use of syn-3, and as the man put it, sissy break-in practices, sometimes 3-4K miles are needed to seat everything. I may be guilty on that count, as my experience is limited to iron jugged shovelheads. (I rebuilt my FLH 10 yrs ago, and it is still smoke free.)
the remedy, is run it hard, high revs, don't be shy about pushing it. If the problem continues, at the next check -up, 5K, they will re-do the top end.
And, while they have it, the heat shield will be replaced. (safety recall. )
Discussion Starter · #15 ·
The MoCo stated that the engine was not broken in yet, that I would need to be more agressive in seating the rings, I feel dumb running on the expressway in 3rd gear,,,, (I thought that 900 mi of 65-75 mph down to Ky. would have done it.) Perhaps the dealers should not recommend switching to synthoil at the 1K service.
The new heat shield is not ugly, but not very stylish either,,,
I would also change brands of oil on next service either Amzoil or Mobil 1 V-twin oil. I had changed to mobil1 at 250 miles never burned any oil after 500 miles of running hard.
I had my bike serviced at 1200 miles (1k service) After the dealer serviced w/syn 3 went through a quart in 450 miles. Went back to mobil 1 and no more oil consumption:soapbox:
Registered Idiot
heat shield
Sorry I don't have any thoughts on the smoke. The v-rod guru at the local dealer liked my header wrap under the stock shields better and recomended not doing the recall. Ceramic coating would be a good alt as well. I was going broke buying new pants after my exhaust torched the legs.
Good luck
No doubt about that. Since I dont ride my bike every day I wont even start it unless Im going to ride it for 20+ miles. Just notice at a stop light how many vehicles have water dripping from the tail pipe. Gotta get it hot enough to get rid of the condensation.
I do not feel it is a consistent high RPM that does it (expressway in 3rd) but hard acceleration and deceleration. Find a large hill that you can use to engine brake down a few times and give it some WOT to get to speed.
1 - 20 of 21 Posts
