1 - 3 of 3 Posts
It is what it is
Seeking information because I am a new Vrod owner looking to max the potential/performance of my 03 Vrod but have a few questions. Currently I have SE exhaust, K&N air filter and PCIII power commander; looking to add SE slipper clutch and SE ported heads; once completed what should I anticipate as for results for money? Should I or must I redo my cams and/or pistons to get maximum HP gain on the pending upgrades? ECM stock vs Stage I what is the deal?
:banghead:
You will not get much more HP out of the heads on a stock 1130. You will need to cam up to get anything. The slipper clutch is the way to go, much improved feel with reduced lever pull.
What are you looking for, street or strip performance? Lots of input on the HD stage 2 cams here; worth looking into.
1 - 3 of 3 Posts
