Yea, actually any year head will work - 02 -04, 05-06 Screaming Eagle CNC ported and 06 and up as cast duplicates of the S/E CNC heads. Just look at what you are buying, don't buy rusted junk. It's out there, beware. So why do you need these heads anyway ? You may be able to send yours out, get +1 mm valves installed and ported for around the same $ if your heads are not destroyed.
The prior owner from a few years back had a "guy" check the valves. He cross threaded a bolt. Tuesday a specialist is looking at the hole to see if it can be reliably fixed without removing the head itself. I figure if they have to take the head off might as well just replace it.
Sent from my ONEPLUS A5000 using Tapatalk
