1 - 3 of 3 Posts
Does anyone know what the difference is between....
40027-01 and 40027-01a?
I know the update (a) was in late 06 or early 07 but was wondering about changes to the width? Before I order a new belt I want to make sure it is the wide one for my 03, if this makes since.
superseded updated part
149tooth: 28t/72t sprockets..14mm pitch..short swing arm..VRCS usa
40627-06.....21mm=.827" wide....240 tire?
40118-05.....25mm=1"
40105-04.....36mm or 37mm=1.4+"
40105-01.....36mm or 37mm=1.4+"(old number)
(Note: for usa 26t you'll need spacers on axel cams)
(Note: use for euro 26t with short s-arm)
150 tooth: 30tx72t sprockets..14mm pitch..short swing arm..VRSC USA 02'-03'/euro
40658-06.....21mm=.827" wide....150T belt....240 tire....30T/72T sprockets.....14mm pitch
40119-05.....25mm=1"
40027-01A...36mm or 37mm=1.4+"....(VRod '02-'03)
40027-01.....36mm or 37mm=1.4+"....(VRod '02-'03)(old number)
(Note: use for usa 26t with long s-arm)
151 tooth: 28t/72t sprockets..14mm pitch..long swing arm..VRSC usa
40144-07.....25mm=1".....240 tire vrscdx '07
(Note: use for euro 26t with long s-arm)
152 tooth: 30t/72t sprockets..14mm pitch..long swing arm..VRSC euro
40145-07.....25mm=1".....'07 euro
Thanks for the information.
1 - 3 of 3 Posts
