Final assembly part breakdown - Left to right.
Swing arm shaved at break “square” and at pulley area
03 front pulley
03 belt
Axel assembly:
.33” custom spacer
03 rear pulley
03 kush
spacer ( 03 I think - the one that fits lol)
14’ comp bowl
14 wheel
.25” custom spacer
03 break assembly
Clearance:
.33” from belt to rim -
2mm clearance pulley to arm - could trim more
2mm clearance rotor bolts to break
4mm clearance rim to break square
Going to 240 shinko tire so I can use this belt and pulley system - shinko 240 tire is almost exact width of the rim.
Pics below is 260/35 tire during the mock-up process - 260 is possible with smaller pully / belt combinations.
Tried offset front pulley (tracked inside)
Tried smaller 1” belt - (too long)
Tried 14’ break (cocked sideways)
Tried countless spacer combinations
03 front pulley
03 belt
Axel assembly:
.33” custom spacer
03 rear pulley
03 kush
14’ comp bowl
14 wheel
.25” custom spacer
03 break assembly
Clearance:
