1 - 1 of 1 Posts
Just wanted to post the specs while the 02's were still available.
DIMENSIONS U.S. METRIC
LENGTH 93.6 inches 2375.6 mm
SEAT HEIGHT 26.0 inches 659.9 mm
GROUND CLEARANCE 5.6 inches 142.1 mm
LEAN ANGLES PER SAE J1168 (LEFT/RIGHT) 32.0° / 32.0°
RAKE/TRAIL 34.0° / 3.9 inches 34.0° / 99.0 mm
WHEELBASE 67.5 inches 1713.2 mm
DRY WEIGHT 595.7 lbs. 270.4 kg
POWERTRAIN U.S. METRIC
ENGINE Revolution™
BORE X STROKE 3.94 in. x 2.84 in. 100.00 mm x 72.00 mm
DISPLACEMENT 69.0 cubic inches 1130 cubic centimeters
COMPRESSION RATIO 11.3:1
FUEL SYSTEM Electronic Sequential Port Fuel Injection (ESPFI)
OIL CAPACITY 4.5 quarts 4.3 liters
FUEL CAPACITY 3.7 gallons 14.0 liters
FUEL CAPACITY RESERVE N/A N/A
MILES PER GALLON 47 hwy / 37 city N/A
LITERS PER 100 KM N/A 5.0 hwy / 6.1 city
EXHAUST SYSTEM 2-into-1-into-2
DRIVETRAIN U.S. METRIC
PRIMARY DRIVE High contact ratio spur gear
GEAR RATIOS (OVERALL)
1st: 11.749 2nd: 7.897 3rd: 6.321 4th 5.456 5th: 4.889
TORQUE 74.0 ft. lbs. @ 7000 rpm 100.3 NM @ 7000 rpm
BRAKES / WHEELS / TIRES U.S. METRIC
BRAKES, DIA. X W.
FRONT
REAR
11.5 inches x .20 inches
11.5 inches x .23 inches
292.1 mm x 5.08 mm
292.1 mm x 5.84 mm
WHEELS
FRONT
REAR
19-inch disc
18-inch disc
48.26 cm disc
45.72 cm disc
TIRE SIZE
FRONT
REAR
120/70ZR-19
180/55ZR-18
INSTRUMENTS
Electronic speedometer with odometer and resettable trip meter with diagnostic capabilities; tachometer; fuel gauge; low fuel light; oil pressure indicator light; engine diagnostic light; security system light (optional); cooling temperature light
COLOR OPTIONS
Anodized Aluminum
1 - 1 of 1 Posts
