Normal for throttle grip to not snap back if only opened partially? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 11-30-2016, 06:23 PM   #1
mattssi
Registered Full
Feedback Score: 3 reviews
I've read a bunch of posts. I've had his behavior with stock bars and stock cables. Seems to be the same with aftermarket bars and Barnett cables.
If I turn half to full throttle, it snaps back closed, but I twist a little bit, it doesn't fully retract/close when I let go.
Throttle grip is lubed, throttle Cable housing is graphite lubed.
Normal? Idle Cable adjusted to the "best" setting I can find.
Thx!
Sent from my STV100-2 using Tapatalk
2011 DX w/ Goodies
mattssi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-30-2016, 08:17 PM   #2
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
loosen throttle lock.loosen return cable some.adj pull cable until slight freeplay without binding then adj return until you get binding then loosen until binding ceases through bar travel from side to side.
pecee is offline   Reply With Quote
Old 11-30-2016, 08:39 PM   #3
mattssi
Registered Full
Tried a few different ways. If I lengthen the throttle Cable I can get it to snap back at low throttle positions, but then the max it opens is like 75% which isn't good. Stoops.
2011 DX w/ Goodies
Old 12-01-2016, 03:02 AM   #4
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
Feedback Score: 1 reviews
Yes the mechanism is a bit sticky and the spring too weak in the beginning.
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 12-01-2016, 03:14 AM   #5
TwinOaks
Registered Full
TwinOaks's Avatar
Feedback Score: 6 reviews
Might not "snap" back with authority but it definitely should not stay open.
As suggested or already checked, lubricate, check all play and check the whole route for any abnormal pinches, kinks or bends.
See manuals, buy manuals, read manuals.
TwinOaks is offline   Reply With Quote
Old 12-01-2016, 10:14 AM   #6
rbabos
Registered Full
One thing not mentioned is cable adjustment. If you have the return cable too tight, it places enough tension in the system to stop or reduce the return. It should have a hair slack in it. If the grip assembly has been r&r at some point check to make sure it's not slipped on too far. This can cause the end of the bar to place pressure in the back side of the grip. Look for about 1/16 in and out free float on the throttle grip to rule that out.
As mentioned, lubed, tension wheel backed off, and no kinks or sharp bends in the routing. Test return at full left and full right on the bars.
rbabos is offline   Reply With Quote
Old 12-01-2016, 12:23 PM   #7
leaderofmopeds
Registered Full
leaderofmopeds's Avatar
Feedback Score: 0 reviews
mine closes better with engine running, guess pulling vacuum on throttle blades. Snapshot of another helpful post from stever975.
leaderofmopeds is offline   Reply With Quote
Old 12-01-2016, 01:09 PM   #8
bogie
VRSCF
bogie's Avatar
Images: 3
Garage
Ive had this too and tried everything, or so I thought. Then dug out the manual and followed the throttle adjustment steps to the letter and got it perfect.
Pretty much as per post above with the screenshot
...it really is just a case of winding off all adjustment and do it from scratch as per the book. Also when you tighten the grip housing do it in order to correct torque on the screws
cheers
bogie
bogie is offline   Reply With Quote
Old 12-01-2016, 02:46 PM   #9
mikeinatlanta
The Massive Pr1ck
mikeinatlanta's Avatar
I have found Barnett to be less than premium quality. I'd go with OE or custom fabricated cables.
mikeinatlanta is offline   Reply With Quote
Old 12-02-2016, 09:23 PM   #10
mattssi
Registered Full
Yeah, I guess I'm just going to have to deal with it. The idle cable I think is too long. Its at its shortest length and I think I need to go shorter. Anything in the opposite direction and it doesn't return at all. I'll hope that vacuum at idle will help it close that last small percentage.
2011 DX w/ Goodies
Old 12-04-2016, 01:01 PM   #11
pecee
Registered Full
pecee's Avatar
make sure you have enough end clearance in the throttle tube on the bar.
Old 12-05-2016, 10:47 AM   #12
ehart814
Registered Full
ehart814's Avatar
Garage
My 08 had this problem when I bought it used. One of the cable housings had come out of its home on the throttle body. I loosened the cables and put the end where it belongs. Readjusted per the book and all is well. Snaps shut immediately.
ehart814 is offline   Reply With Quote
Old 12-07-2016, 01:18 PM   #13
mattssi
Registered Full
Hey guys - sort of embarrassed, but I think the issue is due to having the wrong cables. I have a 2011, so I ordered a 2011 set not thinking. I swapped out front end for 2012 which has 2" extra length. I think as soon as I get the new cables on I'll have enough adjustment available that I can properly adjust them. Stay tuned!!!
Anyone need barnett stealth cables???? Installed and never ridden!
2011 DX w/ Goodies
Old 04-21-2017, 10:53 AM   #14
mattssi
Registered Full
UPDATE: I got the new cables, but still had the same issue.
FIX: SILICONE SPRAY THE INSIDE OF THE CABLES
Unbelievable. These were so non-lubed that there was a squeak when twisting the throttle.
To my surprise when I tried the throttle this morning, it was smooth as butter and SNAPPED back for the first time in years of ownership!
It's amazing. Even though the cables are "lubricated" from the factory, apparently, they miss a few of them. I adjusted the cables, reassembled the housing and bam. Thing works great! The throttle never snapped back from the day I got it until now.
2011 DX w/ Goodies
Old 04-21-2017, 08:00 PM   #15
DannyCoolBeans
Registered Full
DannyCoolBeans's Avatar
^ glad you got it fixed
DannyCoolBeans is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
