Alarm not disarming - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 03-11-2012, 08:16 PM   #1
ldonsouthard
Registered Full
ldonsouthard's Avatar
Feedback Score: 0 reviews
Alarm not disarming
Been having a weird problem with my 2009 Nightrod Special where it doesn't recognize the fact that I have the key fab. Initially, thought it was the key fab battery. Then I thought it was the fact the bike had been sitting for a few months and the bike's battery was dead. I replaced the key fab battery and charged the battery in bike. Also made sure key fab battery was in properly (+ down).
Initially, the bike recognized the key fab again. Then, as I'm riding, I see the key light go on again. Now it doesn't recognize the key again. Is there something I'm missing or do I need to take it to HD?
2009 VRSCDX
➣ Rizoma handlebars
➣ Tab Powdercoated non-baffled exhaust pipes
➣ HD Diamond Grips, footpegs, clutch & brake
➣ More to come when I can afford it!
ldonsouthard is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-11-2012, 08:41 PM   #2
TEAZZR
I Hate Stupid People
TEAZZR's Avatar
1The first thing I would do is replace your key fob battery first . I Know you already did this but it might be a bad battery..
2If it doesn't recognize it then check and see if the manual code for the bikes security works.
3If you have a smart siren - replace or check battery .
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
Vance & Hines Comp. Slip-Ons
SEPST
K&N Cones - Topless
BOSS NOSS - Stealth system
TEAZZR is offline   Reply With Quote
Old 03-11-2012, 10:05 PM   #3
ldonsouthard
Registered Full
Good feedback but I replaced fabs in both keys. What do you mean about smart siren? Is that a special battery on the bike itself?
2009 VRSCDX
➣ Rizoma handlebars
Old 03-11-2012, 10:13 PM   #4
TEAZZR
TEAZZR's Avatar
The smart siren is a actual Plug & Play audible siren for your security.. If all your system did was flash the lights the you don't have the smart siren..
Do you have any diagnostic codes coming up on your Odometer Display when you enter into that function ??
2011 Muscle :
SE Stage II cams
58mm Destroyer TB
6.37 g/s Fuel inj.
SEPST
K&N Cones - Topless
Old 03-11-2012, 11:49 PM   #5
SickRick
Lifetime Premium
SickRick's Avatar
Feedback Score: 3 reviews
key light coming on while riding, is indicative of a code being thrown.
Check your diag code history...
Rick
'10 VRSCDX
Motor: V&H Heads/+1MM-V&H 2:1-SEII Cams-K&N Cones/Bypass - R&D Race Tranny/1:8 2nd/Ceramic Brngs
SEPST:139.87HP/87.1TQ
Rolling: Penske 8983NR/TD AK-20 Dual-Lyndall Rotors/Red+-Brembo P4/34 Calipers-BST CF's-Ceramic Brngs-Conti RA's- Microline Hydraulics
Looks: Polished SS Bolts-Rizoma Rearset/Pegs-Trucklite/LEDMirrors-LED Tail-BlueLED Gages-PVD Black Fork Tubes-Woodcraft Clip-Ons-NMC Windshield(s)-Cluster Relo- Valentine-1 - Blinder 905c
SickRick is offline   Reply With Quote
Old 03-12-2012, 09:05 AM   #6
stever975
Super Moderator
Images: 31
Feedback Score: 1 reviews
Quote:
Originally Posted by ldonsouthard View Post
... Initially, the bike recognized the key fab again. Then, as I'm riding, I see the key light go on again. Now it doesn't recognize the key again. Is there something I'm missing or do I need to take it to HD?
SickRick is right. You have a DTC set in the HFSM (hands free security module).
Here's how to check and clear codes.
BTW, it's a fob (as in key fob) not a fab.
stever975 is offline   Reply With Quote
Old 03-12-2012, 10:19 AM   #7
nightroddersp
james
nightroddersp's Avatar
Images: 8
my key light comes on because of the clutch switch. i remember some one having problems with the back up battery for the security system when they disconected the battery for a long period of time. every time the key light comes on there is a code for the clutch switch. so you surely have a code stored.
nightroddersp is offline   Reply With Quote
Old 03-12-2012, 10:23 AM   #8
ldonsouthard
Registered Full
I believe that fixed it. In other words, I followed directions to check and clear diagnostic errors. Once I finished with that the bike started. I need to take it for a ride to validate this is not a recurring issue but keeping my fingers crossed that I'm back in biz and don't need to spend unnecessary $ at the dealer.
Thanks!
Rick
2009 VRSCDX
➣ Rizoma handlebars
Old 03-12-2012, 02:37 PM   #9
ldonsouthard
Registered Full
Nope problem persisted after riding down the road a bit. Took it into dealer as I was close to my 5k tune. Will post solution when fixed by dealer.
2009 VRSCDX
➣ Rizoma handlebars
Old 03-12-2012, 02:52 PM   #10
stever975
Super Moderator
Images: 31
.... I followed directions to check and clear diagnostic errors. ....
What was the DTC that was set?
Old 03-19-2012, 05:45 PM   #11
ldonsouthard
Registered Full
Just got the bike back from HD service. Turns out it was because there is a sensor in the clutch lever that caused the problem. When I installed the new mirrors I did not have the grip close enough to the clutch lever so the sensor was going off. If I heard the guy correctly the bike thought I started the bike without pulling in the clutch which is not allowed. Might be off on the explanation but the bottom line is I did not have the grip close enough to the clutch lever and therefore sensor was not getting engaged.
2009 VRSCDX
➣ Rizoma handlebars
Old 03-19-2012, 07:55 PM   #12
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
If it continues to fail post the DTC here and save a trip to the dealer. The DTC that was being posted would have told you the clutch switch was failing. From that you probably have figured out it was your changing the levers that was the problem.
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
RustyG is online now   Reply With Quote
Old 03-19-2012, 07:58 PM   #13
ldonsouthard
Registered Full
Yes, I agree. Given I needed to get my 5K tune up anyways I delegated to them in this case. So in the end it cost me $0 to fix.
Quote:
2009 VRSCDX
➣ Rizoma handlebars
Old 03-20-2012, 01:21 PM   #14
Cooze
Hill Country Cruiser
Cooze's Avatar
was that a change in '09? I don't pull in the clutch to start mine..
Cooze is offline   Reply With Quote
Old 03-20-2012, 01:44 PM   #15
stever975
Super Moderator
Images: 31
Quote:
Originally Posted by Cooze View Post
was that a change in '09? ...
No, the clutch interlock switch was added to all HD models in 2007. This works along with the neutral switch as an "either one, the other, or both". So if you're in gear and pull the clutch it should start, if you're in neutral and don't pull the clutch it should start, or if you're in neutral and pull the clutch it should start.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
