2014 VRSCDX Electrical power issue - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 09-01-2019, 09:11 AM   #1
s8spony
When I put the ignition switch into ACC, the instrument cluster powers up, then reboots and cycles over and over again. When I put the switch into "Run", i get very weak power to the headlights (very dim), and almost no power to the instrument cluster. (Odometer is faded and unreadable, no movement of needles.) Bike will not start, no clicking, no power to starter at all. Not enough power to read any codes. Power vision screen is weak and seems to reboot over and over.
Battery voltage is over 13, I checked all fuses.
It seems like it might be a grounding issue, I've checked the ground points under the airbox, they seem tight and clean.
The problem started with a blown ACC fuse, while riding at highway speed the whole bike went dark for a second, the engine stuttered, then it seemed to reboot and I got a CEL and my lights were out. A quick check and I found the blown 15 amp ACC fuse. I replaced it and while riding home the ACC and Lights fuses blew. At this time, they would blow anytime I switched to "Run", even w/o starting the bike. I got about 5 different codes, low voltage or brake switch errors.. About 10 fuses later I thought I found the issue, an aftermarket brake light blinker module, in line withe the rear brake lights. I removed it and the bike seemed fine, all lights bright and no codes on the ECU. I went to start it and I heard a pop, then....nothing. That's when the electric power issue appeared. The cluster seemed dead, no power to the ECU, headlights almost dead, even the front turn signals very dim.
The bike has been fine, I've made no changes outside of standard maintenance for over a year. Any ideas of anything I might be missing?
s8spony is offline   Reply With Quote
Old 09-02-2019, 06:40 AM   #2
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
A) Dim lights and blown fuse sounds like a 12V shortage to ground somewhere or wrong wiring.
Check the main harness for wear and tear.
B) Dim light without blown fuse sounds like dead battery or a loose terminal, probably grounding.
As you mentioned brake switch, I have seen someone reporting similar problems and it was the brake switch.
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 09-02-2019, 06:59 AM   #3
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
I had a look at the wiring diagram: apart from the brake switch, ACC also feeds the fuel tank level gauge and the instrument module. Check the cabling!
Hog of Steel
Old 09-02-2019, 02:09 PM   #4
H-D Heathen
Asatruar
H-D Heathen's Avatar
Images: 29
Did you check the third ground at the bottom of the left frame in front of the gas tank ?
Not everybody likes us, but we drive some folks wild..-Hank III
"Nothing is foolproof if you have a sufficiently motivated fool."
2006 VRSCR-"Not another black V Rod..." She's been beat on, thrown to the ground, abused,neglected & put away dirty..... but the gas gauge works !
"I find as I get older that I have less and less to say about more and more.I thought I was mellowing as I got older,turns out I just don’t give a shit.”
H-D Heathen is offline   Reply With Quote
Old 09-03-2019, 06:37 PM   #5
s8spony
Sad Update
I get 12.61v at the grounds, and fuse box under the seat, and the main 40a fuse under the right tank cover.
Old 09-03-2019, 07:39 PM   #6
s8spony
Update II
I traced it to a short in the rear lights.. removing fender now.
Old 09-08-2019, 02:42 PM   #7
s8spony
Found it!
Main ground strap near battery was loose. I mean, less than 1/4 turn loose: After thinking it was tight I thought I'd go ahead and clean the contacts, when I found the hex bolt to the frame was not tight.Also, an aftermarket brake light flasher module was bad, so fixing both of those things was the fix for everything else.
Thanks, Vrod-ers!
