V-Rod Muscle Tag Relocation - Page 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 10-15-2013, 01:47 PM   #16
V-Buster
Registered Full
V-Buster's Avatar
Garage
Feedback Score: 4 reviews
Quote:
Originally Posted by scorched View Post
All the pieces in the photo are part of the international plate bracket.
I first removed the metal bracket from the assembly by drilling out the rivets that mounted the original metal bracket (in pic) to the plastic.
I Then used tin snips to trim down the plastic bracket until it fit how I wanted, finished the edges with sand appear and a block until smooth and hit the edges with a propane torch for a final smooth finish.
After it was "right", I riveted the original metal bracket back on at the top license plate mounting slots (3/16 rivet with a large backing washer) and bolted it to the original intended mounting area...I had to file out the mount holes in the bracket a bit to help with alignment.
For a light, I used a license plate bracket with LED plate lights in in. Its all very clean and tidy
Funny thing is, I actually spent 2 days on this project doing this 3 different ways, but the final version would have only taken about an hour to do.
Scorched,
Your modifications to the international plate bracket look fantasitc! Doesn't the international bracket come with lights though too? Just curious if you tried to use those, or if you just went straight to the license plate bracket with LEDs in it? Great job, I hope to do the same if I get a Muscle
Buster
V-Buster is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-15-2013, 05:21 PM   #17
scorched
Registered Full
scorched's Avatar
Feedback Score: 0 reviews
The original light on the international bracket is pretty big and would not have worked.
Here's a thread that talks a bit about it
https://www.1130cc.com/forums/showthread.php?t=165348
I cut that area out along with most of the rest of the plastic bracket Basically, I used about 10% of the original international bracket but it was a very important 10%.
Some simply use the metal bracket from the international assembly only and rivet a plate to that. I wanted an OEM ABS plastic look and although a customized touch/part, I wanted it to appear original to the bike.
scorched is offline   Reply With Quote
Old 10-15-2013, 05:26 PM   #18
scorched
Registered Full
scorched's Avatar
Quote:
Originally Posted by flybigjet View Post
This is a great link that show how to use use just the bracket (taken from earlier in this thread)
Old 10-15-2013, 05:27 PM   #19
scorched
Registered Full
scorched's Avatar
Quote:
Originally Posted by V-Buster View Post
Scorched,
Buster
And WADDA ya mean IF you get one?
Stop putting it off and go get one, you can thank me later
Old 10-15-2013, 06:22 PM   #20
V-Buster
Registered Full
V-Buster's Avatar
Garage
Scorched,
Thanks, lots of good info. I really like how you did yours since you used just enough of the plastic to make it look like the way HD "should" have done it from the factory. I will go your route if I get the Muscle
I still have to decide between the F and the DX, but I am leaning towards the F
Thanks again,
Buster
Old 10-15-2013, 07:46 PM   #21
scorched
Registered Full
scorched's Avatar
You can't go wrong with either one.
I picked the muscle because I favored it's more modern look at it just physically fit me better...there also seems to be less of them around. I've always enjoyed being the odd one out.
Old 10-15-2013, 08:14 PM   #22
V-Buster
Registered Full
V-Buster's Avatar
Garage
Thanks, that is what I figured. I too prefer the styling of the Muscle, but I also like the blacked out look. My wife actually prefers the look of the 2014 Victory Judge, so that would really make me the odd one out. Victory doesn't offer ABS on the Judge though and that is a must have for me.
Sorry for the thread hijack...
Old 10-16-2013, 04:17 PM   #23
welltraveled
Registered User
Mounting bracket
Quote:
Originally Posted by CycleBob View Post
Anyone have or seen a mounting bracket to relocate the V-Rod Muscle tag at the end of the fender just below the lights and above the tire, or something like that??? I just bought a new 2013 Muscle and love everything about it except for that air brake of a tag bracket sticking out to the side...
All European models come from the dealer with the plates on the rear fender or just under it, including the muscle rod. It shouldn't be hard to find the bracket as it bolts under the fender and sticks out over the top of the rear tire.
welltraveled is offline   Reply With Quote
Old 03-16-2014, 05:56 PM   #24
GwaiiEagle
Registered Full
GwaiiEagle's Avatar
Took the plunge and the tin snips to the Dog's Ass.
Take it easy on me, it's in but not done.
I think it looks better. Before all you'd see is a huge chunk of plastic.
Name:	ImageUploadedByMO Free1395010387.464311.jpg
Sent from Motorcycle.com Free App
Name:	ImageUploadedByMO Free1395010526.281863.jpg
GwaiiEagle is offline   Reply With Quote
Old 03-16-2014, 06:07 PM   #25
scorched
Registered Full
scorched's Avatar
HELL YEAH Gwaii!
In the end, I ended up trimming the outer edge where it turned down....it was hitting the tail light and wouldn't let it pull up snug. I only used the 2 bolts that attach the metal bracket.
Like this:
NICE JOB and way to jump into it....
Old 03-16-2014, 06:09 PM   #26
scorched
Registered Full
scorched's Avatar
ALSO - when mounted by the metal bracket only, you can tweak and bend it to exactly where you want it too.
Old 03-16-2014, 06:10 PM   #27
GwaiiEagle
Registered Full
GwaiiEagle's Avatar
Thinking about lighting.
Wondered if anyone had used those lighted bolts?
Name:	ImageUploadedByMO Free1395011234.040456.jpg
Old 03-16-2014, 06:32 PM   #28
GwaiiEagle
Registered Full
GwaiiEagle's Avatar
Yea, tweaking the bracket helped.
Never would have thought of this if you hadn't tried it.
The wing tips do touch and may have to go.
Old 03-16-2014, 07:13 PM   #29
scorched
Registered Full
scorched's Avatar
yeah... I had mine bracket on with the tips at first, but not for long.
I had used the light bolts before on a different bike - They work.
I actually have a set of the light bolts here you can have but you gotta come get them!
Old 03-17-2014, 12:40 AM   #30
flybigjet
Departed the Fix.
flybigjet's Avatar
Feedback Score: 23 reviews
The bolts work, but aren't particularly elegant-- especially if you have a frame on the plate and have to take it apart every year to put new stickers on it-- the wiring on the bolts gets in the way.
Here's another option. If you're *really* bored, you can get oem connectors from H-D for a few bucks so you can just make the illuminated plate plug and play.
Pretty cheap, actually. You might find it cheaper if you look around. I just grabbed the first link I saw to show a pic of it.
R.
http://www.cruisercustomizing.com/li...FSISMwodG0EA-A
USAF: 1989-1997. Desert Shield (Saudi Arabia), Desert Storm (Kuwait, Iraq), Provide Comfort (Kurdistan), Restore Hope (Somalia), Uphold Democracy (Hati), Joint Endeavor (Bosnia), Support Hope (Rwanda). USAFR: 1997-2014. Iraqi Freedom (Iraq), Enduring Freedom (Afghanistan). Retired, Oct. 2014.
flybigjet is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
