Small roll pin on my drain plug magnet WTF?!? - Page 4 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 03-16-2010, 07:12 PM   #46
CPTJAM
Lifetime Premium
CPTJAM's Avatar
Images: 21
Feedback Score: 32 reviews
Never say that in print! God forbid, it did get stolen, and the insurace guys shows you this !
TRAVELER: 2006 Roadrod VRSCR, Custom painted Ultrawhite, TTS Supercharger version2.0, TMAX, K&N, Supertrapp V5 exhaust, Pondo Caps, HC Stage II V LED tailight, "A" model bars, Corbin seat, luggage rack, Sumax bags, chrome peg mounts, '08 "D" wheels, polished, rear pulley by Pondo. Slipper clutch. More to come! Old Dyno results: 155 HP 86#TQ
COMET: 2009 AW, painted ultrawhite, a work in progress....105.18 HP, 73.98 torque;
CPTJAM is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-16-2010, 07:28 PM   #47
mwdhand
Gone
mwdhand's Avatar
Feedback Score: 5 reviews
I repeat. I'll torch it and report it stolen. I live on the edge like that. La Vida Loca biatches!!!!!
2007 VRSCX, uncollectable.
Hermaphrodite 2:1 adjustable exhaust, PCIII, Works Street Trackers, Racetech fork springs and cartridge emulators, JE Illusions 300C rear fender, D headlight nacel, Joker machine mirrors, Fitzgerald 26T pulley, 260 metz, various spare parts laying around in my oil pan.
mwdhand is offline   Reply With Quote
Old 03-16-2010, 09:27 PM   #48
El-Bobbo-Cheapo
Registered Full
Feedback Score: 9 reviews
If the pin held it in place, the hole in the case would be the same size.
El-Bobbo-Cheapo is offline   Reply With Quote
Old 03-18-2010, 11:32 AM   #49
mwdhand
Gone
mwdhand's Avatar
Is the overall consensus at this point that this random pin really couldn't have gotten loose from a fully assembled engine? This is my understanding right now; that A.) it is a transmission bearing alignment pin, and B.) it's not possible for one to come out except when the case halves are NOT bolted together. Which means C.) the pin has been hiding in a crevis in this engine since it was assembled at the factory. Are the gurus of this engine in agreement with that?
Rick (their V-Rod guy) at Cajun HD in Lafayette, LA says that that pin IS a transmission bearing alignment pin.
Old 03-18-2010, 03:49 PM   #50
myvrodrocks
myvrodrocks
myvrodrocks's Avatar
Images: 95
Feedback Score: 24 reviews
1. There is no way this pin fell from it's home. If the pin gored it's way out through the aluminum you would have a coffee cup full of material in your oil. Aluminum case shavings and steel bearing surface.
2. There is no way that this pin has anything to do with oil. The shot of the case is not the 1/2 with the pin hole.
3. I am guessing that this pin is to keep the bearing from spinning. Being round I don't think it matters how it goes in.
4. I had to pry it out with a pair of dykes. I don't think it "fell" out. I ordered replacement bearings and they came with the pin in them. IF the guy that inserts the pin is the same guy that assembles the shaft, I doubt he is the same guy that sticks it in the engine. And if he is the same dude....I doubt he does all 3 at the same station.
5. It is entirely possible that HD uses the same pin elsewhere...
6. I know nothing, I am just basing this on my experience rebuilding my own tranny.
myvrodrocks is offline   Reply With Quote
Old 03-18-2010, 03:53 PM   #51
myvrodrocks
myvrodrocks
Images: 95
Maybe the pin is to ensure that the shaft assembly guy does not put the bearing on backwards. The smaller bearing has a seal on one side. Putting it in backwards would not only make your bike run in reverse, but may starve the bearing of oil.
Old 03-18-2010, 04:03 PM   #52
luxlamf
Sanctimonious
luxlamf's Avatar
Images: 105
Feedback Score: 2 reviews
I say you just Torch it anyways.
I Ride My Bike To Trailer Rallies.
luxlamf is offline   Reply With Quote
Old 03-18-2010, 05:19 PM   #53
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
Pin slot in Lower case.
2019 Street Glide Special
2012 Kawasaki Ninja ZX14R
2006 VRXSE Destroyer
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
TaxmanHog is offline   Reply With Quote
Old 03-18-2010, 06:37 PM   #54
mwdhand
Gone
mwdhand's Avatar
So it basically locates the bearing for assembly? Providing the bearing was positioned correctly at the time of assembly then no biggy that the pin's gone now right? If the bearing was put in wrong when it was built then the bearing should have burned up long ago?
Somebody just tell me "don't mean nothin' brother, not a thing". So I can forget about the spare parts in my oil pan please.
Old 03-18-2010, 08:00 PM   #55
Hanzo
GIT UR DONE...later
Hanzo's Avatar
Images: 82
Garage
Quote:
Before you take this advice, can I have your exhaust... : >)
NH to Mexico etc...
Alaska - Cross Country.
New Hampshire To Key West.
It's not to late to be what I might have been ...
02 VRSCA & 2009 VRSCDX
There are only 2 things in the world to worry over: the things you can control & the things you can't control. Fix the first, forget the second...
Hanzo is offline   Reply With Quote
Old 03-18-2010, 08:45 PM   #56
TaxmanHog
Noel
TaxmanHog's Avatar
Images: 277
Garage
In my humble opinion, your OK, keep riding it & stop worrying.
60: 1.393
ET: 9.661
Mph: 139.34
Check Your Grounds
Old 03-18-2010, 09:42 PM   #57
nic_a_bod
"A" is the only way
nic_a_bod's Avatar
Images: 134
Feedback Score: 20 reviews
Quote:
Or use it as your excuse to add some more power
nic_a_bod is offline   Reply With Quote
Old 03-19-2010, 07:57 AM   #58
VrodPete
Elephant Motors Rock
VrodPete's Avatar
Images: 23
Feedback Score: 3 reviews
IMHO it probably is not the pin out of one of your bearings, it's a extra pin that got dropped in the case at assembly. If I'm right you have absolutely nothing to worry about.
Now go back to chasing crazy chicks.
'08 VRSCAW
1402 Oilman Elephant Motor - Fitzgerald Motorsports Style
(Fourteen-Oh-Twous Copicaticus)
HD SE II Cams, 3/8" Falicon Crank, Carillo Rods, CP Pistons, DA Fitz Engine Brace, Destroyer Injectors, Doherty oil pan, DA Fitz Head Port/Polish/+1mm Valves+springs, DA Fitz 58mm TBs, ARP studs, V&H 2nd Gear+Shift Shaft, Motohouligan Airbox, Wegner 2->1 Exhaust with Supertrapp V5
152.77 HP, 101.06 TQ
Other Toys: '01 BMW K1200LT, '76 Honda CB550F, '81 Mooney M20J
VrodPete is offline   Reply With Quote
Old 09-03-2019, 02:09 PM   #59
Bluemanx
Registered Full
Feedback Score: 0 reviews
Exclamation Roll Pin in Oil Pan
All,
I'm new here but have a 2007 Night Rod. I know it's been several years since this posting but was changing my oil over this last weekend and found the exact same thing, a very small roll pin on the drain plug magnet. I did a search on the issue and wound up here. It doesn't seem to have caused any problem.
Bluemanx is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
