Fuel Line Damage - WARNING - Page 14 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 02-09-2011, 11:17 AM   #196
04Chrome
Registered User
Feedback Score: 0 reviews
Hey guys, I checked out my fuel lines and sure enough there was some slight wear in the lines. I used a cable tie with light tension to just pull the lines away from where they were rubbing. Doesnt seem like it will ever be an issue on mine but I'm glad I checked it out anyhow. Thanks for the info here!!
04Chrome is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-27-2011, 08:29 PM   #197
capez
Registered Full
capez's Avatar
Quote:
Originally Posted by roadrkt View Post
I just realized my '08 NRS was leaking gas and spurting it on my exhaust heat shields. I, too, thought I was smelling exhaust from traffic, until I saw the stains on the shields. How dangerous is this and shouldn't there be a recall? Sorry I replied before reading the whole thread.
Which line is that? The return or the primary output?
capez is offline   Reply With Quote
Old 05-27-2011, 08:37 PM   #198
rsc
Killer Service Inc.
rsc's Avatar
Images: 1
Garage
Feedback Score: 8 reviews
The older bikes had the lines running over the rear coil pack and rubbing on the bolt and such.
If you wire-tie them and put some rubber over them in that area you will be okay.
Just check them every so often to make sure they are okay .
2003 turbo
2012 Ultra Classic
V-rod mechanics 101:
Old 10-08-2014, 02:49 PM   #199
Janazar
Registered User
Me Too
I know this is an old thread, but wanted to add to it. I have an '04 I bought used and have been riding since March. This just happened to mine. About 12k miles, and it looks like it's been a long term thing and finally wore a pinhole all the way through.
Unfortunately, the dealers are trying to sell me a full kit for replacement, rather than the lines I need. Quick fix, but eBay probably gets my business on this one.
Never too late to check. If you've got the cap off, look for wear through the line covers and replace as necessary.
Janazar is offline   Reply With Quote
Old 10-08-2014, 04:28 PM   #200
207
Registered Full
Janazar.. Thanks for reviving an old thread. I went out and checked the lines on my '03 and sure enough it was starting to rub through the outer sleeve.
I cut 2 three inch lengths of 3/8 hose and put one on the lower hose where the rubbing took place and on the upper hose I slid that under the frame cross member below the fuse box in case rubbing was taking place there.
Name:	VROD fuel line rub.jpg
ID:	390530   Click image for larger version
Name:	VROD fuel line repair.jpg
207 is offline   Reply With Quote
Old 10-09-2014, 11:25 AM   #201
Janazar
Registered User
Nice plan. I'll put some tubing around the new one before I install it.
Old 10-10-2014, 10:08 PM   #202
JRROD
Registered Full
The new lines have different angles to fix the problem
JRROD is offline   Reply With Quote
Old 08-30-2015, 10:04 PM   #203
WADDSTER
Registered User
Need help with fuel pump inspection, or removal, gas only coming out of one fuel line ? Bike wont start but will run on starting fluid....was in storage for 2 years...could it be the injectors, fuel pump , or what ? Please help !!!!!
WADDSTER is offline   Reply With Quote
Old 08-30-2015, 11:16 PM   #204
Bruce Helland
Registered Full
Feedback Score: 3 reviews
Where did you disconnect the lines? If you disconnect the pressure line you won't have any fuel on the return side. Are you having trouble with the bike? When you turn the key on can you hear the pump run?
Bruce Helland is offline   Reply With Quote
Old 08-31-2015, 11:58 PM   #205
WADDSTER
Registered User
Yes I did take both lines loose...had a brain fart...thought for a minute fuel should come out both nipples on fuel flange...yes the pump pumps out the outgoing nipple...but not really very robust...got a feeling its way under 50 psi...will rig up a pressure gauge and hose tomarrow and get an accurate reading....bike sat for awhile in storage...put fuel treatment in tank...not much fuel in there though...ment to fill tank and forgot....then started bike up and sucked treatment into lines and injectors. ..probly ruined fuel pump...ran for 10 min. Then quit....wont start but will run on ether...any ideas ? Anyone ?
Old 09-01-2015, 02:52 AM   #206
Hoffa65
Registered Full
Hoffa65's Avatar
Feedback Score: 6 reviews
With lines connect remove cap shine flashlight in tank turn on key and run switch look in tank for misting fuel. Most likely a split supply line from pump to flange
Hoffa65 is offline   Reply With Quote
Old 09-29-2015, 02:59 AM   #207
SmokeyGold04
Registered Full
Feedback Score: 1 reviews
Good thread and info for new owners (like me) of old bikes.
SmokeyGold04 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
