P1355 Rear Coil - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 04-21-2016, 02:26 PM   #1
idougary
Muscle A4 HOG
P1355 Rear Coil
Hi,
My bike threw a P1355 code so I replaced the rear coil but this has not fixed the problem and I still have the P1355 code. Can anyone help with suggestions as to how to troubleshoot from this point?
Ian.
Ian
2012 Candy Orange VRSCF
A4
HOG
idougary is offline   Reply With Quote
Old 04-21-2016, 05:21 PM   #2
BIG POPPA 66
stupid question but did you clear the previous code
Old 04-21-2016, 05:47 PM   #3
Hoffa65
Hoffa65's Avatar
Them :-)
Hoffa65 is offline   Reply With Quote
Old 04-22-2016, 06:04 AM   #4
Images: 31
Originally Posted by idougary View Post
...My bike threw a P1355 code so I replaced the rear coil but this has not fixed the problem and I still have the P1355 code. Can anyone help with suggestions as to how to troubleshoot from this point?...
You should always clear the DTCs after reading them but you can tell if the code is "current" or "historic" by the behavior of the CEL (check engine light).
When you first turn on the ignition the oil pressure, security, and check engine lights all illuminate. After 4 seconds the security light and CEL go out (the oil pressure light goes out after the engine starts). After this 4 second initiation period the security and check engine LEDs may do one of the following three:
  1. If these remain off, there are no engine, security, or chassis DTCs.
  2. If these stay off for 4 seconds and then one or both illuminate again and then go off after 8 seconds, there is at least one historic DTC.
  3. If these stay off for 4 seconds and then one or both illuminate again and remains lit, there is at least one current DTC.
(The ABS LED will illuminate in a similar fashion to the security light and CEL to indicate ABS DTCs on bikes with ABS, however; its behavior is a little more complicated and some ABS DTCs will not clear until the bike has been operated above 16 km/h = 10 MPH).
Old 04-22-2016, 07:27 AM   #5
idougary
Muscle A4 HOG
Yes I did clear the codes after I replaced the coil but when I started the bike again it only fired on the fornt cylinder and the code came back. I also tried resetting and removing the power commander but the bike still only runs on the front cylinder and throws the P1355 code.
Ian
A4
HOG
Old 04-22-2016, 09:01 AM   #6
Feedback Score: 16 reviews
Did you make sure the spring inside the rubber tube that connects the coil with the spark plug is stretched out enough to make good contact on both ends? This has been an issue on occasion.
Elgavilan is online now   Reply With Quote
Old 04-22-2016, 09:25 AM   #7
Images: 31
The P1355 DTC means the voltage at the primary winding of the rear ignition coil is "out of range" high. This out of range voltage occurs when the ECM tries to fire the coil by grounding the Y/BE (yellow with blue stripe) wire that connects the coil "C" circuit to ECM pin #11. Four things can cause this:
  1. a short to voltage on the Y/BE wire
  2. a bad ECM
  3. a bad coil
  4. a bad piggyback device
Since you replaced the coil and removed the PC you only have two other sources of the problem.
Old 04-22-2016, 11:01 AM   #8
idougary
Muscle A4 HOG
Thanks for the help guys, much appreciated.
The rubber boot for the plug connection is new, when I bought the coil it all came as one assembly.
I'll check the continuity on the wires next.
Ian
A4
HOG
Old 04-22-2016, 06:42 PM   #9
swap the two coils to verify the condition of the new coil. If the symptom moves to the front cylinder its a bad coil.
Old 04-26-2016, 02:05 AM   #10
idougary
Muscle A4 HOG
Looks like the bike will need to go to the stealers. Not good but I've tried everything else.
Ian
A4
HOG
Old 04-26-2016, 05:26 AM   #11
thunderdemon
thunderdemon's Avatar
Did you check the spark plug?
thunderdemon is offline   Reply With Quote
Old 04-26-2016, 06:45 AM   #12
Images: 31
The P1355 DTC is related to problems in the rear cylinder coil primary circuit. Bad spark plugs or other secondary circuit problems would have triggered one of the loss of combustion DTCs: P1353, P1356, P1357, or P1358.
Old 04-26-2016, 11:24 AM   #13
thunderdemon
I know but it was worth to check
video with my stage 2 cams,motohooligan and akrapovic with DB killer
Old 05-03-2016, 11:58 AM   #14
idougary
Muscle A4 HOG
Tried the plug and checked the continuity of the wiring all to no avail. Sadly the steeler is picking it up on Thursday.
Ian
A4
HOG
Old 05-03-2016, 12:57 PM   #15
thunderdemon
good luck! let us know how it went,or what they did.
