Codes - Page 4 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Technical
Reply
Thread Tools Display Modes
Old 08-15-2007, 06:46 PM   #46
street rodder
Lifetime Premium
street rodder's Avatar
Images: 23
Garage
Feedback Score: 6 reviews
Guess no one has run into this yet.
Handy with the V Rod
street rodder is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-17-2007, 10:38 AM   #47
street rodder
Lifetime Premium
Images: 23
Garage
Need help diagnosing this one. Max where are ya.
Old 08-17-2007, 11:18 AM   #48
Bill
VRF0RUMS ORIGINAL
Bill's Avatar
Garage
Feedback Score: 7 reviews
Quote:
Send him, or RJ a PM. Wish I could help more.
Bill is offline   Reply With Quote
Old 03-21-2008, 08:21 PM   #49
Sharkey
Sharks-Parts
Feedback Score: 105 reviews
question?
as newer years and different models are introduced does this thread on codes
https://www.1130cc.com/forums/showthread.php?t=2
that is fantastic and very cool of MAX to post ever need updating?
I was wondering as newer models with updated part numbers of electrical and engine parts.... does the code library grow???
The individual activity of one man with a backbone will do more than a thousand men with a mere wish...
the above information in this post in my opinion only....I recomend you check my advise with an expert....use this info at your own risk
Sharkey is offline   Reply With Quote
Old 04-13-2008, 08:57 PM   #50
warhawk426
Feedback Score: 0 reviews
cobra fueler & engine diagnostic light
just finished installing cobra f1200 fueler and amsoil air filter. per cobra instructions the unit is correctly installed. all 3 lights come on,then only one green when bike is running. stock pipes that have one inch drilled thru. that 1 inch pipe mod did make a big difference in performance but now my engine diagnostic light is on ? I did not take the bike for a ride. dont tell me i got to bring my v rod to a dealer! that light had never come on before!
warhawk426 is offline   Reply With Quote
Old 04-13-2008, 09:15 PM   #51
rjrivero
Friend of Max.
rjrivero's Avatar
Images: 128
Feedback Score: 13 reviews
Quote:
Check your codes. It's a sticky at the top of this section.
What you have just read is my opinion. I assume no responsibility for anyone applying my opinions to their own VRSC motorcycle, much less their own lives. Do not duplicate these stunts. They are preformed for you by trained monkeys. There is nothing professional in what you have just read.
V-Rod Editor American Iron Magazine
I will no longer be recieving PM's. Please contact me via the email option. Thanks.
RJ
rjrivero is offline   Reply With Quote
Old 04-13-2008, 09:38 PM   #52
Max
Max's Avatar
Images: 2545
Feedback Score: 66 reviews
Yes the code list has grown by a couple of codes, I'll see if I can get them updated.
R.I.P. My dearest Jeannie, you are in my heart always.
The road of life sometimes seems full of potholes. RIP Jeannie, Alex and Brian. I'll never forget any of you.
Max is offline   Reply With Quote
Old 04-21-2008, 02:53 PM   #53
kphotog
alarm problem
Thanks for the codes. Went for Big Sur ride in California and came back to Carmel to get gas. Then the engine wouldn't start. Alarm key displayed on instrument dash. Called Harley dealer after it was closed. Nice service manager from Corte Madera was on hand to help out and told me about the diagnostic codes. I wrote down the codes and didn't know what it was for so thanks to you, I know now.
KWong
2002 Silver Vrod
Morgan Hill
Quote:
Originally Posted by Max
List of all v-rod fault codes
RANKING DTC STATUS FAULT CONDITION SOLUTION
1 P0605 Current ECM flash error 4.29 DTC P0603, P0605
2 P0605 Historic ECM flash error 4.29 DTC P0603, P0605
3 P0603 Current ECM EEPROM error 4.29 DTC P0603, P0605
4 P0603 Historic ECM EEPROM error 4.29 DTC P0603, P0605
5 U1300 Current ECM serial data low 4.12 STARTS, THEN STALLS
6 U1301 Current ECM serial data open/high 4.12 STARTS, THEN STALLS
7 U1300 Current TSSM serial data low 4.12 STARTS, THEN STALLS
8 U1301 Current TSSM serial data open/high 4.12 STARTS, THEN STALLS
9 U1300 Current IM serial data low 4.12 STARTS, THEN STALLS
10 U1301 Current IM serial data open/high 4.12 STARTS, THEN STALLS
11 U1064 Current Loss of TSM/TSSM serial data-at ECM 4.32 DTC U1064, U1255
12 U1016 Current Loss of all ECM serial data-at TSSM 3.19 DTC U1016
13 U1096 Current Loss of IM serial data-at TSSM 3.20 DTC U1096, U1255
14 U1255 Current Missing response-at TSSM 4.32 DTC U1064, U1255
15 U1064 Current Loss of TSM/TSSM serial data-at IM 2.15 DTC U1064, U1255
16 U1016 Current Loss of all ECM serial data-at IM 2.14 DTC U1016
17 U1255 Current Missing response-at IM 4.33 DTC U1096, U1255
18 P1003 Current System relay contacts open 4.14 SYSTEM RELAY CHECK
19 P1002 Current System relay coil high/shorted 4.14 SYSTEM RELAY CHECK
20 P1001 Current System relay coil open/low 4.14 SYSTEM RELAY CHECK
21 P1004 Current System relay contacts closed 4.14 SYSTEM RELAY CHECK
22 P1009 Current Incorrect password 4.30 DTC P1 009, P1010
23 P1010 Current Missing password 4.30 DTC P1 009, P1010
24 P0373 Current CKP sensor intermittent 4.25 DTC P0373, P0374
25 P0374 Current CKP sensor synch error 4.25 DTC P0373, P0374
26 P0122 Current TP sensor open/low 4.23 DTC P0122, P0123
27 P0123 Current TP sensor high 4.23 DTC P01 22, P0123
28 P0107 Current MAP sensor open/low 4.20 DTC P01 07, P0108
29 P0108 Current MAP sensor high 4.20 DTC P01 07, P0108
30 P0117 Current ET sensor voltage low 4.22 DTC P01 17, P0118
31 P0118 Current ET sensor open/high 4.22 DTC P01 17, P0118
32 P0112 Current IAT sensor voltage low 4.21 DTCP0112, P0113
33 P0113 Current IAT sensor open/high 4.21 DTCP0112, P0113
34 P1351 Current Front ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
35 P1354 Current Rear ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
36 P1352 Current Front ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
37 P1355 Current Rear ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
38 P1357 Current Front cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
39 P1358 Current Rear cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
40 P0261 Current Front injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
41 P0263 Current Rear injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
42 P0262 Current Front injector high 4.24 DTC P0261, P0262, P0263, P0264
43 P0264 Current Rear injector high 4.24 DTC P0261 , P0262, P0263, P0264
44 P0562 Current Battery voltage low 4.28 DTC P0562, P0563
45 P0563 Current Battery voltage high 4.28 DTC P0562, P0563
46 P0501 Current VSS sensor low 4.27 DTC P0501 , P0502
47 P0502 Current VSS sensor high 4.27 DTC P0501 , P0502
48 P1651 Current Check engine light open/low 4.6 IM SELF DIAGNOSTICS
kphotog is offline   Reply With Quote
Old 05-11-2008, 03:01 PM   #54
vrod06
Bike won't start
I installed a tab fuel manager with pipes yesterday, had some problems with check engine light and uninstalled and the reinstalled the fuel manager and the problem went away (no more check engine light). Rode about 60 miles yesterday w/o any problems. Rode the bike to work today and now the bike won't start, it turns over but will not start. I have some error codes, they are p0113 and p0263. I reset them and they don't come back but the bike still will not start as if it's not getting fuel. I also got a 'no rSP' message, have no idea what that means. Any ideas, I don't want to mess with the bike too much and it acted fine all day yesterday and this morning. Please help.
vrod06 is offline   Reply With Quote
Old 05-11-2008, 08:01 PM   #55
MY_VRSCDX
matt blk & fire hot
MY_VRSCDX's Avatar
Images: 38
Question
Quote:
Originally Posted by vrod06
I also got a "no rSP" message, have no idea what that means.
this "no rSP" code through me off too for a bit. then I got it! no run switch power!
or turn on the run switch for this test. now I can see the code.
The older I get, the better I was
Run'in on Empty, but the F'in gauge doesn’t work, so I probably have 1/2 a tank!
MY_VRSCDX is offline   Reply With Quote
Old 08-07-2008, 11:12 PM   #56
Sharkey
Sharks-Parts
that is some great info there.....thanks
Old 09-13-2008, 09:58 PM   #57
gguillie
Never too late!
gguillie's Avatar
More code questions
I have these three codes showing on my 2008 VRSCDX:
C1095, C0562, and E1216. Anyone know what these codes mean?
I also have the b1154 code which is the clutch ground fault. I believe this may be due to the new black handlebars I installed. Many years ago I painted the handlebars on a dirt bike. The kill switch was the button type with a metal strap. After I installed the painted bars, I couldn't kill the engine because the paint acted like an insulator between the metal of the bars and the strap. Once I scraped away some paint and established a ground, the kill switch worked fine. Got a hunch the same situation exists here with the clutch lever assembly and the bars. After installing the black bars the clutch lever assembly and switch housing fit as they should. Now I can't start the bike in any gear but neutral and the security key icon comes and goes while I'm riding.
GPG
gguillie is offline   Reply With Quote
Old 09-13-2008, 10:32 PM   #58
Max
Max's Avatar
Images: 2545
C1095 front brake switch open
C0562 device voltage low
E1216 I don't have listed.
Old 09-14-2008, 07:48 PM   #59
gguillie
Never too late!
gguillie's Avatar
Thanks for the info
Max,
After I visit the dealer I'll let all know if there is resolution. Got to tell you, these codes are making me paranoid -- and perhaps rightly so.
Prayers are always with you,
Greg
GPG
Old 09-25-2008, 08:12 PM   #60
ToySldr
Registered Full
Feedback Score: 2 reviews
I have a problem, my button underneath the speedo has stopped working. It said "diag" but there are no codes that come up with that. I changed out the ECU and it had been working fine but today when I updated it, I started having the problems.
ToySldr is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
