clutch pack hard as rock - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 05-03-2019, 06:07 PM   #1
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
Feedback Score: 4 reviews
I finally got around to slipping in my billet clutch basket from a recent group buy here and put in a barnetts slippwr clutch pack also. 3 times I have put it together (LESS THE OIL) and whenI pull in the clutxh lever its solid as a rock and no movement.
I verified it works with the button mechanism out so thats not the issue here.
Cant figure this out anyone have this issue when installing a clutch or basket??
I get zero movement on the clutch handle installed. Its free uninstalled meaning thw lever and button is free moving.
triple checked torques and clutxh pack disks too
'06 street rod SuperCharged (and proud of it)
'46 Norton 16H w/SideCar
Tie_One_On is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-03-2019, 08:01 PM   #2
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
so I figurednit out but need some specs for the clutch spring guide springs bolts torque
the manual says to torque them to 9.7 nm but that is obviously for a stock basket and clutch pack.
anyone have an installation sheet for a slippwr clutch with torque info??
Old 05-04-2019, 07:32 PM   #3
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Feedback Score: 11 reviews
So what was wrong?
Regards,
John
Quote:
2007 VRSCX 0461 / 1400
2002 Road King Classic
Old 05-04-2019, 09:33 PM   #4
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
Quote:
Originally Posted by RustyG View Post
So what was wrong?
the clutch actuator bolts when torqued to the spec in the book became bottomed out and no more travel of the actuator i backed them out to where it looks to be in a few videos online and it works now.
I have a call into barnetts to ask what the spec is for these spring bolts torque
Old 05-05-2019, 05:43 AM   #5
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
Feedback Score: 1 reviews
something sounds wrong
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 05-05-2019, 03:55 PM   #6
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
It's not a matter of tightening the bolts, but wrong assembly, for example too many discs.
Hog of Steel
Old 05-05-2019, 06:47 PM   #7
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
Quote:
hmmm
I slipped in the entire packet as shipped other than the lifter plate I replaced.
I will pull the clutch pack out and count each.
the barnetts slipper is a single extra disc so if should be 10 friction and 8? separator disks
i will shoots pixs of it all
Old 05-05-2019, 07:18 PM   #8
RustyG
Lifetime Premium
RustyG's Avatar
Images: 99
Maybe the bolts just to long?
Regards,
John
Old 05-05-2019, 08:37 PM   #9
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
not sure.
still have the stock clutch pack so i can alway use it if this one is the shitz
Old 05-05-2019, 09:42 PM   #10
knight rod rob
Registered Full
knight rod rob's Avatar
Feedback Score: 0 reviews
knight rod rob is offline   Reply With Quote
Old 05-06-2019, 07:03 AM   #11
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
maybe the slipper cluch hub is on the ramp, this is not an uncommon assembly failure
Hog of Steel
Old 05-06-2019, 10:09 PM   #12
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
I pulled it all apart tonight see pics and I think but not 100% sure that you may be correct jan. It looked like it might have been up on the slipper ramps when i pulled out the disks and spacers.
9 disks 8 spacers is correct count and the hub was free so I know that wasnt it.
I will put it back in tomorrow and see.
The ramp pics are after i made sure it was seated.
ID:	532289   Click image for larger version
ID:	532291   Click image for larger version
ID:	532293   Click image for larger version
ID:	532295   Click image for larger version
Old 05-08-2019, 06:15 PM   #13
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
Talked to barnetts about the spring torque, they said 5-6 nm.
In addition to this they said it sounds that the 3 special friction plates may not be installed in the pack correctly, so I will pull it apart and look at the order.
What a pain. Almost (not really) ready to slap the stock clutch pak back in there and call it quits.
Old 05-08-2019, 06:18 PM   #14
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
How stupid am I.
I just noticed while looking at the pics I uploaded, this is a HD slipper clutch pack and not a Barnetts clutch pack.
Look at the HD numbers on the thing, I hold in my hand the entire purchase (did not only purchase disks and plates).
Old 05-11-2019, 11:45 PM   #15
RONVROD
My Last Ride
RONVROD's Avatar
Images: 7
Garage
Feedback Score: 2 reviews
Quote:
Originally Posted by Tie_One_On View Post
How stupid am I.
Are you staggering the top disk? If not then the top disk has to go into the short slot between the deep slots.
RONVROD is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cycle Visions Pack Rack, Vinyl Covered Rigid Hard Bags, Kury Tall Sissy bar etc... aehn eBay Auction Links Section 8 11-20-2017 07:23 PM
between a rock and a hard place Bad Attitude V-ROD Technical 8 11-15-2009 07:31 PM
Barnett extra-plate clutch pack redrazor Classified - For Sale - Parts 2 10-31-2007 04:59 AM
Clutch Pack Shoe V-ROD General 2 10-27-2006 06:35 AM
