Oil bypass valve ? - Page 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 05-15-2019, 10:23 AM   #16
Originally Posted by Calais08 View Post
I’m just going off the light going out ,I pulled apart and the relief valve is at the pin end is that open or shut?
Valve is under spring pressure, so closed until it's set spring pressure allows it to open. If the valve is stuck at the bottom this can explain it not bleeding the pressure off and the surge blowing the seal out. In a reverse situtation, if the valve hangs open, idle pressure will be very low. As far as I know the only adjustment is shimming the spring or a different spring rate. Neither of these should need to be done but make sure the valve is free to float and not stick.
Old 05-16-2019, 04:37 AM   #17
Calais08
Was the relief valve on pump put 1130 pump on and algood
Next issue bike fires for 5sec then dies have to cross solenoid button not working ,
My mechanic lost key previous and it’s had no fob but after sitting with no engine .....
I hvnt had time to read forum for awnsers
Calais08 is offline   Reply With Quote
Old 05-17-2019, 05:49 AM   #18
Calais08
Fixed was a earth wire on rocker cover had broken off
Similar Threads
Thread Thread Starter Forum Replies Last Post
O2 bypass plugs?? BigBillyStyler VRSCR 1 07-24-2010 08:28 PM
Breather hose bypass zaatarnightrod VRSCDX 21 06-14-2009 01:44 PM
08 DX - Electronic Parts remove / bypass mex V-ROD Technical 4 10-20-2007 07:22 AM
Broken Coolant Overflow - can I temporaily bypass it tomjones V-ROD Mechanical 3 04-22-2007 05:56 AM
Power Comander bypass map? CaptClose PowerCommander (All Versions) 4 02-05-2006 02:14 PM
