starter selonoid clicking but starter only sometimes turns over - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 07-09-2019, 01:28 AM   #1
krissconley
Registered Full
Feedback Score: 0 reviews
Hey Guys, I gotta 02 v-rod and more and more often lately there is a hesitation of everything when I push the start button. Now, the starter selonoid is only clicking and the starter isn't turning over at all. Any suggestions? My thanks in advance.
krissconley is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-09-2019, 01:30 AM   #2
krissconley
Registered Full
...also, the battery good. Occasionally the starter will engage it cranks normally with no sluggishness.
Old 07-09-2019, 09:35 AM   #3
Pete D
Guest
Posts: n/a
Can you hear the solenoid clicking, or just the starter relay under the back of the air box cover? First things first, I’d check connections, including earths....
Old 07-09-2019, 04:35 PM   #4
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
remove and clean earth contacts on front head,and check the others on both heads,lower rear frame.if still try relay,theyre cheap.
pecee is offline   Reply With Quote
Old 07-12-2019, 12:41 AM   #5
sigma9
Lifetime Premium
Thats an easy one, if its like the issue I experienced on my 05 CVO its a relay on the fuse box. Dealer replaced the battery, Starter and cables. No fix. The relay is the same as the high beam relay if I am correct, so you can do a quick test then buy the part if it works. The PN is 31522-00C I now always carry a spare. I have replaced 3 in 9 years. Hope this solves your problem.
sigma9 is offline   Reply With Quote
Old 07-15-2019, 11:03 PM   #6
dig10
Registered Full
dig10's Avatar
Images: 4
Feedback Score: 3 reviews
Yes I had the same problem on my 02 twice, was the starter relay on both occasions.
[B]A veteran is someone who, at one point in their life, wrote a blank check made payable to ‘My Government ’ for any amount, up to and including their life
1ATF Nui Dat Vietnam 69-70
dig10 is offline   Reply With Quote
Old 07-31-2019, 02:50 PM   #7
Pete D
Guest
Posts: n/a
Having experienced exactly the same issue this week, mine was both a failing starter relay, and connections that had pushed through the plastic relay housing block. New relay fitted, and the wire connectors encouraged from the back to ensure tight contact, my problem has been resolved. Hope the OP has had similar luck; if not, check the female spade connectors have not been pushed away from the relay!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
