Newbie 2003 Vrod owner - seeking assistance on stalling - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 06-03-2019, 08:46 AM   #1
jonathankahana1
Registered Full
Feedback Score: 0 reviews
Hi Forum:
I just purchased a 2003 VROD. The bike appeared to be in perfect condition and the former owner had nothing but great things to say about it. Since the bike was 16 years old I brought it to an HD specialist for a full service, hydraulic flush and replace, plugs, new Metzler tires, etc. The bike was originally purchased in 03 and was traded in in 07 with 17k miles. the guy i bought it from had it 12 plus years and put another 7500 miles on it. This bike does not have a scratch on it and seemed to be very well cared for. Both owners were very experienced riders.
I am finding that the bike is stalling on occasion typically on downshifting and sometimes right after starting the bike and giving it gas. I've had the bike just a few weeks and yesterday had to have it towed as it stalled a bunch of times and i felt unsafe riding it. I noticed the clutch lever that was just flushed went limp for a while then came back eventually. Anyone have any advice here? the HD specialist ran diagnostics during my service and nothing came up. I am now nervous to ride the motorcycle. Are there any sensors in the clutch set up that may be faulty telling the bike to stall? The issue seems to have gotten WORSE since the hydraulic clutch was flushed and refilled with fresh fluid.
Thank you so much. I want to get out there again and ride!
I noticed a bunch of posts from 2003-2005 regarding a downshifting/stalling issue, does anyone know if they pinpointed a cause? I would imagine if this bike went 16 years without the issue, it might be something different from those problems.
From the forum it seems any of the following could be the issue:
• Oxygen sensor or other sensor at issue
• Clutch sensor, air in clutch system (why would clutch go limp?)
• Idle air tubing or sensor
• Exhaust map to aftermarket exhaust (Rinehart Racing Pipes)
• Fuel flange
• IAC – no idea what this is but was mentioned on forum many times
• Electronic issue with speed sensor cables
• EFI tuning update
• Loose battery
• Coil wire issue?
Last edited by jonathankahana1; 06-03-2019 at 08:54 AM. Reason: additional information
jonathankahana1 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-03-2019, 09:53 AM   #2
stever975
Super Moderator
Images: 31
Feedback Score: 1 reviews
Quote:
Originally Posted by jonathankahana1 View Post
Hi Forum:
• Fuel flange
• EFI tuning update
• Loose battery
• Coil wire issue?
Concerning your bulleted comments:
  • The 2003 VRSC doesn't have O2 sensors
  • The 2003 VRSC doesn't have a clutch sensor
  • I'm not sure what an "idle air tubing" is but the VRSC fuel injection system uses an idle air bypass port controlled by the IAC (idle air control) "motor". This IAC is connected to the ECM (electronic control module) and engine idle speed is adjusted to a programmed value when ever the engine is running if the TPS (throttle position sensor) is indicating a closed throttle and the VSS (vehicle speed sensor) is indicating the bike isn't moving.
  • You definitely need some sort of fuel map adjustment if you have an aftermarket exhaust like "Rinehart Racing Pipes".
  • Fuel flange leaks can mess with the fuel pressure and can be checked with a fuel pressure gauge.
  • IAC was discussed above.
  • Yes, a bad VSS or bad VSS wiring could cause idle issues.
  • EFI tuning was discussed above regarding the aftermarket exhaust.
  • I assume you mean loose battery connections and yes, this or the ground connections on the front and rear cylinder heads should be checked.
  • Plug top coil connects to the spark plug with a spring inside the boot. the low voltage coil connections aren't likely to cause this type of problem, but bad coils have been known to.
You say you went to an HD specialist. That doesn't mean much when your bike is a VRSC model. Most HD specialist don't know how the V-Rod works. You could also have leak(s) in the throttle body boots that will mess with the idle air. You say this HD specialist ran diagnostics. This can also be done using the IM (instrument module) and the trip meter reset switch as explained in this post. Remember to clear the codes after reading and noting what you see.
stever975 is offline   Reply With Quote
Old 06-03-2019, 10:02 AM   #3
jonathankahana1
Registered Full
Thank you so much for the reply Steve!. The HD specialist I brought it too is a VROD rider as well. I am new to Harley Davidson and am not sure of all my repair facility options. I guess i should just tow it back to him and have him look at all these things as i feel unsafe riding it, would you agree? What's interesting is the clutch lever went limp for a while then pressured back up somehow. This is right after the clutch was bled and refilled.
Old 06-03-2019, 10:52 AM   #4
stever975
Super Moderator
Images: 31
Concerning towing and having these things checked, yes, that might be the best if you're not comfortable doing this yourself (i.e., don't have the tools, time, skills). Concerning the clutch, the only thing I can guess is that there's air in the system and bleeding is necessary.
Old 06-04-2019, 07:19 AM   #5
jonathankahana1
Registered Full
Input from conversation with HD service specialist
Hi Steve,
I talked to HD and there are no recalls on my VIN.
I described what was going on and it seems he thinks there are numerous reasons a 16 year old bike can do this, but considering the issue got worse or at least more apparent after hydraulic bleed, its probably in that system, he encouraged me (the HD dealer was in Utah) to bring the bike in and have them recheck the bleed and also the master and slave clutch cylinders. Depending on what the clutch system is "thinking" this could cause the stalling at standstill and while downshifting. Does this make sense to you?
J
Old 06-04-2019, 10:52 AM   #6
stever975
Super Moderator
Images: 31
Hi Steve,
J
I don't see how an improperly bled clutch would result in the engine stalling you describe. A clutch that's not bled properly may not release and this could make shifting from neutral to first gear difficult (or impossible). However, the engine should still run fine if in neutral when at stand still or while moving in gear. The clutch system has no sensors that can communicate to any other component on the bike. Your stalling problem is most likely one of the other things mentioned before:
  • Bad fuel map
  • Air leaks in intake
  • Dirty or damaged IAC system (should throw a DTC e.g., P0505)
  • Ignition coil(s) problems. These should throw codes at high RPMs and high engine load (open throttle) e.g., P1353, P1356, P1357, and/or P1358
  • VSS problems (should throw a DTC e.g., P0501 or P0502)
  • Fuel pressure problems
  • bad battery connections or ground points on cylinder head
Old 06-04-2019, 11:18 AM   #7
jonathankahana1
Registered Full
Thanks, I listed all this stuff out and provided to the mechanic. He did say an issue with the internals like the master or slave cylinder could cause stalling on downshift and making shifting difficult and finding neutral difficult. He'll hopefully get to the root of the problem. I will keep you posted and thanks!
Old 06-04-2019, 04:39 PM   #8
Elgavilan
The Hawk
Elgavilan's Avatar
Images: 21
Feedback Score: 16 reviews
Put it in neutral, start it and see if it stalls, no clutch involved, should be a good clue!
Sent from my iPad using Tapatalk
It's not how fast you go, it's how fast you get there!
Elgavilan is offline   Reply With Quote
Old 06-05-2019, 07:50 AM   #9
jonathankahana1
Registered Full
stalls occasionally in neutral.
Hi All,
So i brought the bike back to the mechanic and the battery was dead and couldn't start the bike. He is thinking the problem is the charging system (may need new battery and check terminals etc.) and there is an issue with the seals/pistons in the clutch lever. I think he's gonna check the clutch internals as well.
would a weak battery cause stalling downshift and sometimes in neutral but mostly on downshifting?
Old 06-05-2019, 09:22 AM   #10
stever975
Super Moderator
Images: 31
Hi All,
It shouldn't. The voltage regulator will limit the alternator load on the engine. If the battery is really low and your sitting at idle, the alternator won't have enough current output to recharge the battery. If the system voltage drops below 12 volts and doesn't rise as the engine speed goes above 2000 RPM, a P0562 DTC will be set but the engine shouldn't stall.
Old 06-05-2019, 09:30 AM   #11
jonathankahana1
Registered Full
Dang
I was hoping the fact that the battery died and the clutch went limp would point the mechanic to the underlying problem but i guess i'm hearing neither would cause in motion stalling. Well i left the mechanic with ALL the great tips i got on this site and am hopefully he will check all of them and i'll be out there riding soon. If not i have had my eye on a 2008 Kawasaki Concours to add to the collection while i repair the vrod!
Old 06-05-2019, 12:28 PM   #12
jonathankahana1
Registered Full
mechanic update
The update from the mechanic is that the clutch master cyl needs to be rebuilt and re bored as well as a new battery (battery is 3 years old). Then hydraulic fluid in clutch system will be drained and refilled again. I hope this is it. He checked about 10 other things and all was perfect. UPDATE: so the bike no longer stalls! It seems the clutch master cylinder was failing AND since the bike was not used regularly the last few years there were some fuel contaminants in the system. We put fresh gas in there and treated it with seafoam. It seems to have worked itself out and the bike runs great now. Also made sure the gas cap was tightened all the way, it wasn't!
J
Old 07-02-2019, 11:02 PM   #13
SoCalVrodder
Registered Full
This post couldn't have been more timely. My experience is eerily similar to yours. I also bought a 2003 about a month ago and had new tires put on and had a local mechanic, (although not a H-D specialist) perform a 20k service. I just did a 500+ mile trip this past weekend to reposition the bike from where I live to where I work and had no problems. However, I am on day 2 of commuting 15 minutes to work and have had the bike stall on me the same way you described although without the clutch going limp. The last time was as I was downshifting coming off the freeway. Fortunately, I was able to pull the clutch and restart it while coasting.
Glad to hear you seem to have the issue resolved. I will share this post with a mechanic if it continues. If you don't mind me asking, what did the clutch master cylinder rebuild and fluid replacement cost you. Looking to understand what to expect if I have to do the same
Thanks.
SoCalVrodder is offline   Reply With Quote
Old 08-22-2019, 08:18 AM   #14
martin983
Registered Full
Bad fuel map can be
martin983 is offline   Reply With Quote
Old 08-23-2019, 11:30 PM   #15
stevemcgov
Registered Full
I'd bet the Clutch going soft And coming back is unrelated.
Maybe a bad Bleed and fill job and some remaining air in the system came loose and then popped up to the reservoir?
"The bike appeared to be in perfect condition and the former owner had nothing but great things to say about"
So it ran okay when you bought it, and AFTER the service it's crapping out?
Did you get any seat time on it before the service?
He did the Plugs, are they the recommended plugs and Gap? Needs to be.
Sometimes the Springs in the Coil paks get compressed and you need to stretch them out a bit...
- Was the gas old, is there water in the tank?
I would Punt:
Use a turkey baster with a tube taped on it or something to remove all the fuel you can,
add some super with a heavy dose of SeaFoam and let it sit for a day or to? Deep/Slow or Trickle Charge the battery in the meantime with the MAXI-FUSE out regardless of charger type.
Then burn the fuel and additives by running it on the stand along with some upper engine cleaner spray down the throttle bodies a little at a time varying RPMs with your right hand and crossing your fingers with your left!
YOu could use a spray bottle and sea foam (go EZ)
Watch the temp and/or be ready to ride it EZ to get some fresh air on the Radiator.
Fans should come on at some point if it is sitting still running.
Maybe it will clear up that way - have more fresh super on hand and repeat with a bit seafoam and fresh fuel...
stevemcgov is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
