Quote:
Originally Posted by v-rodjohn
hi all i wonder if any one can explain these codes to me and tell me what i need to do U1255 U1016 and B1005 the bike has started to run like crap and feels like it's running weak..any help will be appreciated
john
With that many DTCs on a bike that's still running, I'd guess a bad ground connection.
First check the battery negative wire. Then check the screws for items 1 and 3, and then the screw for items 8, 9, and 10 shown in this picture:
Then check the engine ground connector to the frame shown here (it runs from the oil sump to the frame cross member):
The B1005 DTC is usually an unplugged fuel sensor or a short to voltage on the Y/W (yellow with white stripe) wire that connects to IM (instrument module) terminal #11 but this shouldn't affect the engine's performance.
