What did you do to your V-Rod today - Page 525 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 07-01-2019, 06:18 PM   #7861
stevemcgov
Registered Full
Feedback Score: 0 reviews
Thanks for the info.
I go with mobil1 v-twin synth- IMHO comparable to amsoil, I added very little if any in the 3
riding seasons with my D, or about 1400 miles/yr - ya, I'm a local sport rider, not a long haul cruiser! lol
stevemcgov is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-03-2019, 01:55 PM   #7862
original owner
Lifetime Premium
original owner's Avatar
Images: 21
Feedback Score: 5 reviews
Daniii Its been some time since .
Correct me if wrong . But which 100K is this ?
I thought you had 100 ten years ago
Considering selling my 69 XLCH
original owner is offline   Reply With Quote
Old 07-04-2019, 02:37 PM   #7863
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
Feedback Score: 1 reviews
100.000 trailer miles
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 07-04-2019, 05:11 PM   #7864
Tictac46
Guest
Posts: n/a
today update
changed brake fluid front and rear. changed clutch fluid, polished swingarms and added roll bag😎👨🏻*🔧
Old 07-05-2019, 11:02 AM   #7865
MAR-VEL
Registered Full
Quote:
Great looking bike mate...What brand of bag Is that fits in there really well . do you have a link ? ... Thanx
MAR-VEL is offline   Reply With Quote
Old 07-05-2019, 12:00 PM   #7866
Tictac46
Guest
Posts: n/a
thanks. here’s link
https://rover.ebay.com/rover/0/0/0?m...2F400448287040
Old 07-05-2019, 09:31 PM   #7867
stevemcgov
Registered Full
Front Brakes -
Pulled Front Calipers - Cleaned them up. Put a little oil on the piston bases
1 piston stuck. Put wood shim in other caliper, and worked the lever got the stuck one loose. Installed new Pads.
Went to put in "speed Bleeders" but they did not fit. #$%^&&*
Got a some air in the line with that fail...
Bleed/Flushed a bunch of BelRay dot 4 through both calipers. Jiggled the
brake lever a ton and slowly got air out.
Pinned the Brake lever back and left it right handle pointed up for a couple hours - Heard that helps a few more trapped air bubbles come up to reservoir...?
Took out and broke in pads. Pretty Smooth
* Mines a D so I bent the Rear Brake Lever down, much better control on it now
so using both brakes together works nice.
*Oberon Brake/Clutch Levers are pretty fine controllers and worth the money IMHO.
EBC Semi Sintered Brake Pads
BelRay Dot 4 : 355ml bottle is enough to do Clutch-and both brakes unless maybe you are going to flush a ton extra through.
In 2 years I'm going to Steel lines up front.
Old 07-09-2019, 06:08 AM   #7868
Daniii
Geezer
Daniii's Avatar
Images: 681
That was the "Century club": age plus miles. I've got 173K by that count.
Batzilla / Dan "the Elder"
This is as amusing as watching chimps in a zoo, only without having to dodge flung poo. (Coonass)
Daniii is offline   Reply With Quote
Old 07-09-2019, 06:10 AM   #7869
Daniii
Geezer
Daniii's Avatar
Images: 681
Talking
Quote:
At least. I'm on my third set of tires on the trailer.
Old 07-18-2019, 01:31 PM   #7870
vegetate
Registered Full
Installed Kuryakyn 4357 Ribbed Folding floorboards for passenger.
My wife say it much more comfortable now. Well.. Happy wife - happy life
Original footpeg mount swapped left to right for shifting floorboards little bit more forward.
ID:	533177   Click image for larger version
ID:	533179   Click image for larger version
vegetate is online now   Reply With Quote
Old 07-26-2019, 07:59 PM   #7871
Mr. Orange 645
Registered Full
None of this was done "today," but has been done over the course of the last couple weeks.
1. Made radiator insert screens (the pic was actually of my Guardian Bell, but you can see the screen in the background) Click image for larger version
2. Installed the fender eliminator kit from Altered Designs (Thanks, Keith!). There was one on there already, but it was just turn signals. I wanted a kit that did running lights, brake light, and turns.
3. Moved the license plate to the side with an axle mount bracket and added LED light bolts. Click image for larger version
4. Installed front LED switchback turn signals. As running lights, they are a very bright white halo. But when the turn signal is activated, they the white halo turns off, and the inside of the signal flashes amber. They are crazy bright!! I included a pic of the actual bulbs, purchased from NThreeAuto on Amazon. Click image for larger version
ID:	533327Click image for larger version
ID:	533329Click image for larger version
5. Of course I needed resistors at that point, so I drilled some holes in the frame under the seat an mounted the resistors where they are out of sight. I spliced the wires in to the turn signal lights in the main wire bundle under the seat and rewrapped it, so it all looks factory. Click image for larger version
ID:	533333Click image for larger version
I also several weeks ago sprayed all the tins with matte black PlastiDip. My 13NRS is the vivid black with the perforated graphics down the side. I love the flat black, but its a bit plain. My next plan is to vinyl wrap it in gloss black with metallic flat black racing stripes. And instead of "Harley Davidson" on the sides, I'm going to add just the outline of the bar and shield in grey.
Mr. Orange 645 is offline   Reply With Quote
Old 07-27-2019, 06:12 AM   #7872
Daniii
Geezer
Daniii's Avatar
Images: 681
Started packing for Sturgis. Looks like the zipper on one of the muscle bags has failed. As has the zipper on every HD item I have ever owned. So the contents (raingear) goes into a plastic bag. Not to keep the rain gear dry, but to keep it fro mildewing. Leaving Monday first light.
Old 07-27-2019, 02:09 PM   #7873
quake
Black Denim F
quake's Avatar
Quote:
Same experience here with those damn HD item zippers. Have a great time at Sturgis. One of these days I will be there. Ride safe.
quake is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
