What did you do to your V-Rod today - Page 515 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 06-30-2018, 06:00 PM   #7711
Jay F
Registered Full
Jay F's Avatar
Feedback Score: 0 reviews
Very nice!
2011 VRSCF
2009 XL1200C
2018 XG750 Wifes
Jay F is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-01-2018, 08:34 PM   #7712
Daniii
Geezer
Daniii's Avatar
Images: 681
Was informed last year that my rear brake light switch wasn't working (front was). Inspector said, fix before next year... I procrastinated, and today went out and wiggled the connectors. And that fixed it. Woo Hoo.
Batzilla / Dan "the Elder"
This is as amusing as watching chimps in a zoo, only without having to dodge flung poo. (Coonass)
Daniii is offline   Reply With Quote
Old 07-03-2018, 11:05 AM   #7713
fitzfn
Registered Full
2014 Night rod special, put some arlen ness grips on it , went to take it out for a short cruise , check engine light and battery light came on, died on me on the way home, found out it wasn't charging , tested the stator - tested ok, so figured its the voltage regulator
Vance and Hines 2 into 1 comp exhuast
k&n filter
Power Commander 5
fitzfn is offline   Reply With Quote
Old 07-03-2018, 11:43 AM   #7714
Beer.Tom.Rod
Agave Idiots :)
Beer.Tom.Rod's Avatar
Images: 18
Minor changes... LoL!
In the process of swapping out engines prepping to upgrade my original 1130 to 1320.
Installing a '05 SE 1250 with a handful of updates installed.
this alone should be a substantial upgrade to what i had.
My last upgrade experiment attempt hasn't worked out so well, live and learn!
Heads way too big for bottom end, not big enough cams,
So... back to the drawing board, rather than have major down time, bought an '05 SE 1250 and have updated that (somewhat). Will proceed over the next while and off season of rebuilding my original 1130 to 1320 with some serious cams, my destroyer spec heads and the other goodies I am accumulating
Figure the 1320 is a good platform as the only real serious mods are to the cases which are readily available and piston size upgrade.
Then I can stay with stock rods and crank if there are any future issues, theses are also readily available.
Remember, I'm on the West Coast of Canada, not very much support out here like you guys in the Eastern States!
Cheers!
2006 VRSCR "Chucky"
Vivid Black with custom paint scheme.
Engine is under construction ....
My Indian name is..."RUNS WITH BEER"
Beer.Tom.Rod is offline   Reply With Quote
Old 07-03-2018, 11:51 AM   #7715
RF_R_US
Lifetime Premium
RF_R_US's Avatar
Images: 35
Feedback Score: 1 reviews
Sounds like a nice project. Just curious where you got the used 1250 and what's the going rate for one? I'd build a beast engine but thinking a nice used 1250 would be a good upgrade to my 1130.
Thanks,
John
RF_R_US aka John
"D" headlight, Kuryakan LED mirrors, Heavycycles Stage II Tail Light, Rinehart 2:1, Works Custom 15.25" Shocks, Racetech Forks (best investment $$$ can buy), Wicked Airbox, Thundermax
(now I can REALLY screw up this bike), etc., etc.
Other Fossil Fuel Burning Toys: '05 FLHTCUI, '96 KLR650, '73 Chevy Nova SS yeah it's :bad:
RF_R_US is offline   Reply With Quote
Old 07-03-2018, 02:49 PM   #7716
smallwoodcd
Registered Full
smallwoodcd's Avatar
Garage
Last Friggin Payment
Made the last payment on the F and checked that the balance was zero on their website.....now its all mine!
2.5 years early....not saving a ton of interest but every little bit helps. Now lets just hope they get me my title muy pronto.
You guys have a good and safe July 4th holiday!
smallwoodcd is offline   Reply With Quote
Old 07-03-2018, 11:57 PM   #7717
06CVO
119WHP/88lbsTQ
06CVO's Avatar
Took Camille on a 150 mile ride...beautiful day it was..
"Camille"-'06 CVO Screamin' Eagle VRSCSE2 Power Commander 5 Topless/K&N, TAB Performance, Arnott AIR, Progressive front lowering springs, DayMaker LED,
Metzeler 260, Galfer Wave Rotors
Honda CBR 600 Long Gone...
06CVO is offline   Reply With Quote
Old 07-05-2018, 11:00 PM   #7718
SpokaneVRod
Registered Full
SpokaneVRod's Avatar
I’ve been looking for an solution to the low sissybar height for my wife. I bought a drag specialty round bar, removed he factory pad and drilled some holes. TheDS Nat is pre-threaded 1/4x20 Bought some stainless bolts, added a sundowner rear pillion and will order a backrest pad. If I did it again I would move the holes up a bit and hopefully be able to suck the upper bar in a bit.
I also bought a shorty vrod bar to run 99% of the time the wife is holding on.
ID:	528793   Click image for larger version
ID:	528795   Click image for larger version
ID:	528797   Click image for larger version
SpokaneVRod is offline   Reply With Quote
Old 07-08-2018, 09:57 AM   #7719
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
Found two bolts missing on the sprocket. It made some noise. I am lucky i didnt go down.
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 07-08-2018, 11:07 AM   #7720
Sharkwood
Full Throttle
Sharkwood's Avatar
Images: 3
Tried to install Progressive Drop in front lowering springs. Contrary to what Progressive says, they won’t work in the 2014 NRS. The forks need to be removed and disassembled. Not real happy now that I installed their rear 444 that are 1” shorter.
Sharkwood is offline   Reply With Quote
Old 07-08-2018, 01:05 PM   #7721
H-D Heathen
Asatruar
H-D Heathen's Avatar
Images: 29
Feedback Score: 6 reviews
I looked at the alloy engine covers and the swingarm, decided they could use a good polishing.
Went for a ride to the grocery instead.
Home now for a short time, leaving again soon.
Not everybody likes us, but we drive some folks wild..-Hank III
"Nothing is foolproof if you have a sufficiently motivated fool."
2006 VRSCR-"Not another black V Rod..." She's been beat on, thrown to the ground, abused,neglected & put away dirty..... but the gas gauge works !
"I find as I get older that I have less and less to say about more and more.I thought I was mellowing as I got older,turns out I just don’t give a shit.”
H-D Heathen is offline   Reply With Quote
Old 07-09-2018, 11:17 PM   #7722
karlbaxter08D
Registered Full
I dropped it off with my buddy so he can put ArgleBargle's exhaust on it for me. I'll be in the field spraying corn and wont have time to do it myself for a few days and I want my new toys put on now
Will get a call to the local dyno tuner to get it in the end of the week to dial it in. Ill post pictures when I pick it up.
karlbaxter08D is offline   Reply With Quote
Old 07-10-2018, 08:30 AM   #7723
MotorMike
Registered Full
MotorMike's Avatar
After laying the muscle down last month I put on new bars, replaced the left side hand switches, grip and rear view mirror. Today I will replace the left side exhaust.
17 VRSCF
MotorMike is offline   Reply With Quote
Old 07-10-2018, 02:13 PM   #7724
Daniii
Geezer
Daniii's Avatar
Images: 681
Mike, be prepared for replacing the shifter shaft. Many with left side lay downs have discovered their shifter shaft was damaged, only when it failed. (I've lost two in 98,000 miles.).
Old 07-10-2018, 10:55 PM   #7725
MotorMike
Registered Full
MotorMike's Avatar
Quote:
Thanks Dan I took it for a good ride today and it appears to shift ok. Between the handlebars on the F and the mini boards I just put on they took most of the beating. However, I am taking it into the dealer for the 1k service and told them to check it. Yea I laid it down with only 800 miles on the odometer!
17 VRSCF
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
