Signal stabilizer - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 05-22-2019, 12:30 PM   #1
Jberes
Signal stabilizer
I have an 07 night rod special and Iím trying to wire in my signal stabilizer but canít seem to get it working. Can any tell me where to posi tap the wires into? Or pictures. Iíve tried the male end of the signal harness right before the rear signals. Thanks..
Jberes is offline   Reply With Quote
Old 05-22-2019, 01:31 PM   #2
Images: 31
Do you mean a turn signal "load equalizer"?
If so, it should have two inputs and a ground. One input should go to a V = violet wire and the other should go to a BN = brown wire that are fed by the TSM/TSSM/HFSM (turn signal/security module) pins 5 & 6 respectively.
These wires run from the TSM/TSSM/HFSM to the front and rear turn signals. On a 2007 VRSCDX the easiest place to find these is under the passenger seat at the TSM/TSSM/HFSM.
You say you tried at the male end of the rear turn signal harness. That should be a 6-place Multilock connector and the turn signal feeds are in positions 3 and 5 with grounds at positions 2, 4, and 6. The load equalizer inputs should go to positions 3 and 5 and the ground should go to 2, 4 or 6 (all are equivalent).
Old 05-22-2019, 01:40 PM   #3
Jberes
Okay thanks. And yeah it’s a load equalizer, there’s also a blue wire that come with it do you know where that goes? I’ve tried connecting it to the blue one on the female end of the harness but didn’t work.
Old 05-22-2019, 07:46 PM   #4
Didn't your load equalizer come with instructions? What brand is it. Might help to know that.
2003 VRSCA Ė Gone but not forgotten.
Old 05-22-2019, 07:49 PM   #5
Jberes
Yah sorry.. it’s the custom dynamics universal signal stabilizer.. and the instructions aren’t very helpful
Old 05-22-2019, 09:42 PM   #6
Jberes
the wiring harness I’m holding is to the rear signals. Is this where I posti tap into with the signal stabilizer?
Old 05-23-2019, 06:36 AM   #7
Images: 31
the wiring harness Iím holding is to the rear signals. Is this where I posti tap into with the signal stabilizer?
Yes that's the 6-place Multilock connector I mentioned above. The V and BN wires feed the turn signals, the blue feeds the running lights and the blacks are all grounds. I just read these instructions from Custom Dynamics for their Signal Stabilizer (I added comments in italics):
  1. Make sure bike power is off. (Remove MAXI fuse.)
  2. Locate wires going to rear directional lights. If a Run-Brake-Turn module is installed, Signal Stabilizerô must go before Run-Brake-Turn module. (the wires you need are in the 6-place Multilock connector that feeds the rear turn signals.)
  3. Attach Purple wire from Signal Stabilizerô unit to left side rear directional wire using Posi-Tapô connectors supplied with kit.
  4. Attach Brown wire from Signal Stabilizerô unit to Right side rear directional wire using Posi-Tapô connectors supplied with kit.
  5. Attach Black Wire from Signal Stabilizerô unit to ground wire in wiring harness using Posi-Tapô connectors supplied with kit.
  6. Attach the Blue Wire from Signal Stabilizerô unit to constant power or running light wire in harness using PosiTapô connectors supplied with kit.
  7. Before turning power on, make sure the load switch on the side of the stabilizer is in the ďnormalĒ position. (See next page for Diagram). (Before step 8. below I would perform a turn signal "load learn" procedure:
    Replace MAXI fuse and then disconnect battery negative for at least 1 minute and then reconnect it.
    turn ignition switch OFF-ON
    activate left turn signal lamps for 4 (or more) flashes
    activate right turn signal lamps for 4 (or more) flashes)
  8. Turn key on and test turn signal, running lights, and brake lights for proper operation. If you experience fast flashing from the turn signals, turn the key off, move the recessed switch on the side of the stabilizer to the ďhighĒ position (see diagram on next page), use a small screwdriver or similar object to move the switch. Repeat this step once the switch is moved.
  9. Test Alarm for proper operation, if equipped.
Old 05-23-2019, 08:37 AM   #8
Jberes
Okay thanks for the help. The stabilizer must be broke. I’ll try n return it. I’ve tried a few times in this spot. And decided to try the front.. now my headlight and front signals don’t work , hopefully I just unhooked something putting it back together . will have to look at it again when I get home from work.
Old 05-23-2019, 08:50 AM   #9
Images: 31
Okay thanks for the help. The stabilizer must be broke. Iíll try n return it. Iíve tried a few times in this spot. And decided to try the front.. now my headlight and front signals donít work , hopefully I just unhooked something putting it back together . will have to look at it again when I get home from work.
Technically, it doesn't matter if you hook to the front or back. The front and back signals are fed by the same outputs from the TSM/TSSM/HFSM. The only distinction is left or right.
Old 05-23-2019, 09:46 AM   #10
Jberes
Yeah I know. That’s why I’m thinking I just bumped something loose. Thanks again for the help!
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to install Customdynamics turn signal stabilizer G4ses How-To 6 08-10-2015 02:08 AM
Signal stabilizer/left turn signal problem Gunboy V-ROD Technical 4 03-31-2013 08:05 PM
Signal; Stabilizer Question Koa04 V-ROD General 2 08-18-2009 10:02 PM
Custom Dynamics signal stabilizer G4ses V-ROD Technical 6 01-09-2008 04:38 PM
