Please help me identify this part - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 07-23-2018, 09:09 AM   #1
jeremylowe
This part was on my magnetic oil plug when I changed the oil in my 2003 VROD. I think it might have broken off the transmission. Does anyone recognize it? I need to find the part number. It has a "6" or "9" stamped on the end.
ID:	528943   Click image for larger version
jeremylowe is offline   Reply With Quote
Old 07-23-2018, 04:05 PM   #2
streetrodracer
Debris large enough to have part numbers ?!!
First guess secondary cam chain tensioner shim. Second guess cam bucket shim, but two of those side by side are needed to be the same diameter as a penny. I don't see anything in the gearbox that looks like that but other guys here on the site may know more than me - looks like the wear around the outside indicates a spring or the end of a shaft that is hollow rubbing it, hence my first choice. Funny thing is guys joke about finding debris large enough to have part numbers on it on their magnetic plugs, but you actually did ! Not funny thing is it got beat up getting to the magnetic plug so wonder what if anything else got bent, damaged, etc. Any other metal on the magnetic plug ?
streetrodracer is offline   Reply With Quote
Old 07-23-2018, 04:12 PM   #3
jeremylowe
There wasn't anything else on the magnetic plug but this. The Harley parts counter looked at their box of shims to see if it matched any and it did not. Thanks for you input.
Old 07-23-2018, 04:22 PM   #4
coastrider
coastrider's Avatar
Probably of no help, but I have seen this part in a pic before, either on this site or one of the Facebook groups. Came out on the drain plug the same. Exactly the same with a number stamped. Is definitely not a valve shim because they are much harder material than that appears to be and they are not stamped.
coastrider is online now   Reply With Quote
Old 07-23-2018, 05:37 PM   #5
jeremylowe
Thanks for the tip. I'll start scouring the forum to see if I can find who else has had to deal with this.
Old 07-23-2018, 06:33 PM   #6
streetrodracer
F.Y.I. the secondary tensioner shim P/N is 40095-01K and I know RustyG among many others here on the site has experience with setting that secondary cam chains tension with the tool P/N HD-45334 and adding shims to get rid of the start-up rattle. What doesn't make sense is how someone could drop that shim inside the engine as its on the outside cap end of the tensioner, so it may be something else ? Someone here will know. If you still have the oil filter I would open it up ( a sharp chisel around the base will do it if you don't have a cutter, and wear thick gloves ) and inspect for any small non metallic debris like aluminum. Hopefully you lucked out. Recheck at next oil change, shorter interval though.
Old 07-23-2018, 07:59 PM   #7
There are no numbers on the secondary shims, just plain old machine marks on both sides.
Old 07-23-2018, 08:13 PM   #8
jeremylowe
Thanks, Streetrodracer. This helps.
Old 07-23-2018, 08:14 PM   #9
jeremylowe
Are you saying that this is not a secondary shim because of the number on it?
Old 07-23-2018, 08:22 PM   #10
coastrider
coastrider's Avatar
Just a thought, there isn't any kind of filter bypass valve fitted in this engine is there? Seen similar looking things to that in by pass valves on other engines. Maybe one of the guys who is well versed in v rod engine rebuilds might know.
Old 07-23-2018, 08:30 PM   #11
Panman
Panman's Avatar
Could it be the 6th gear they forgot to install?
Panman is offline   Reply With Quote
Old 07-23-2018, 08:39 PM   #12
CrawlinMike
Guest
Posts: n/a
Lol I’ve had notifications on for this since the beginning but with the lack of a like button or something, letting you know I feel the same way and you made me laugh good .
Old 07-23-2018, 10:04 PM   #13
streetrodracer
Finally, the missing 6th Gear !
Man, that's a small 6th gear, with no teeth ! Probably explains why when I shift into it there ain't no 6th gear there and I 'm just stuck with 5th, same RRM. So I don't see any shims like that in the oil pump and like Ron says the secondary cam chain shim is not numbered, just machine marks, which makes sense since you add the SAME shim once or twice to adjust it. Cam bucket tappet shims are numbered, but like 2.60 (M.M.) not 6 or 9 plus they are 1/2 the size of a penny. To the great and all knowing OZ of all V Rods out there - we await your infinite wisdom ! Pick up the white courtesy phone please ! Call Scott Fitzgerald, Fitzgerald Motorsports Greenville OH or Ray Vreeland, Vreeland H-D Bloomsburg PA or maybe Stever975 the moderator here can chime in with knowledge - Hey it's a Monday give it a few days - other guys know but they are out riding since it's not snowing.
Old 07-24-2018, 11:32 AM   #14
Since you now there are bits floating around in there; We did a group buy a couple years ago for the Dimple magnets ( oil filter & drain plug) The filter ones are most effective but even the drain plug is about 50X stronger than the stock piece. Do a search & watch the videos.
Old 07-24-2018, 07:54 PM   #15
Secondary tensioner shims
Here is a couple of secondary cam tensioner shims. No numbers on them.
Name:	Secondary tensioner shim 1.jpg
ID:	528955   Click image for larger version
Name:	Secondary tensioner shim 2.jpg
