"pop" on acceleration
625 views 3 replies 4 participants last post by  rjrivero
#1 ·
I installed a 2 into 1 Bub Rinehart pipe, a PCIII usb and a SE air filter-semi topless on my otherwise stock 2003 V-rod. The bike was running fine but recently I have noticed a "pop" while accelerating. It doesn't happen all the time, but enough that it raises my concerns. Any ideas? Could it be my map? AFR not quite right?
#2 ·
"Popping" on accel usualy means lean.
You might want to post this question in the EFI section. There are quite a few more knowlegable people that check in there regular. I think there is a seperate sub-section for PCIII
#4 ·
Which map are you using for this setup? I would venture a guess that it is the Map that's your issue.
