When I went riding this morning, while turning on a street my engine stopped (dead) & wouldn't start up. On the odometer "EIP" came up. After I let it sit for a minute, it did start back up & didn't have any more problems with it. I couldn't find anything in the manual on what "EIP" means. Can someone please help me with this? I would greatly appreciate it!
The bank angle sensor is a safety feature that cuts off power to the engine if it leans over 45 degrees, it figures you fell over. It's supposed to be disabled in a trike.
It is a 2007 VRSCA trike. It did say EIP on the odometer. I didn't turn that corner any different than I have done in the past. I'm near a H-D dealer & will check with them on Tuesday when they open & have them check the tsm/tssm? This is my third V-Rod trike & I have never had this happen. What is that by the way....tsm/tssm?
The t in tip is small cursive and looks like an e on the screen. TSM is turn signal module, TSSM is turn signal/security module. HFSM is hands free security module.
Scott bypassed the tip sensor completely due to the radical riding his bike goes through. It's not an easy bypass, as it requires taking apart the ECM and some talent with a soldering iron.
He posted it on the forum, but if you can program the TSSM to "Sidecar" mode, it's a better fix.
not much on this error after searching, thanks for the info. It just happened on my new trike, we'll see how long it takes the dealer to figure it out, they didn't have a clue.
Cuando salí a montar esta mañana, mientras giraba en una calle, mi motor se detuvo (muerto) y no arrancaba. En el odómetro apareció "EIP". Después de dejarlo reposar por un minuto, volvió a encenderse y no tuvo más problemas. No pude encontrar nada en el manual sobre lo que significa "EIP". ¿Puede alguien por favor ayudarme con esto? ¡Me sería de gran aprecio!
Hello friend, you were able to fix your error eip?, I have the same problem and do not know how to fix it. The bike turns off every 3 minutes I'm walking.
hola amigo pudiste solucionar tu error eip?, tengo el mismo problema y no se como solucionarlo. La bici se apaga cada 3 minutos que camino.
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
