P1355 Rear Coil - Page 2 - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 05-03-2016, 02:17 PM   #16
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Originally Posted by RustyG View Post
swap the two coils to verify the condition of the new coil. If the symptom moves to the front cylinder its a bad coil.
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 05-08-2016, 03:54 AM   #17
idougary
Muscle A4 HOG
The steeler swapped the ecm and the bike runs on two cylinders. Sadly a new ecm here in Scotland is £411 of our pounds. And that's before fitting and flashing to the right map for the bike.
Ian
2012 Candy Orange VRSCF
A4
HOG
idougary is offline   Reply With Quote
Old 05-08-2016, 04:51 PM   #18
thunderdemon
thunderdemon's Avatar
replace it with a Daytona twin tec ECM-tuner with wide band O2 sensors and auto tuning,best tuner on the market and the bike will always run at best performance
http://www.daytona-twintec.com/VRFI.html
video with my stage 2 cams,motohooligan and akrapovic with DB killer
thunderdemon is offline   Reply With Quote
Old 03-20-2019, 07:07 AM   #19
Dococonnor69
Originally Posted by idougary View Post
Hi,
My bike threw a P1355 code so I replaced the rear coil but this has not fixed the problem and I still have the P1355 code. Can anyone help with suggestions as to how to troubleshoot from this point?
Ian.
Hi,
Just wondering what was wrong with your bike in the end when it threw up the P1355 code.
Doc
Dococonnor69 is offline   Reply With Quote
Old 03-20-2019, 07:19 AM   #20
Images: 31
Post #17 states that the ECM was bad.
Old 07-11-2019, 07:11 PM   #21
GLRSR1951
Originally Posted by stever975 View Post
The P1355 DTC means the voltage at the primary winding of the rear ignition coil is "out of range" high. This out of range voltage occurs when the ECM tries to fire the coil by grounding the Y/BE (yellow with blue stripe) wire that connects the coil "C" circuit to ECM pin #11. Four things can cause this:
  1. a short to voltage on the Y/BE wire
  2. a bad ECM
  3. a bad coil
  4. a bad piggyback device
Since you replaced the coil and removed the PC you only have two other sources of the problem.
I am having the same problem on my 2006 Dyna Wide Glide. I replaced the coil but did not fix the problem.
1. What's the Y/BE wire?
2. Is there a way to test the ECM?
3. Is there a way to test the coil other than on the bike? (Maybe I swaped in another
bad one)
GLRSR1951 is offline   Reply With Quote
Old 07-16-2019, 06:59 AM   #22
Images: 31
bad one)
I don't have technical data on Dyna models so I'm not sure if the VRSC wiring color codes are the same but:
  1. The Y/BE wire for VRSC bikes is used to fire the coil by connecting this wire to ground through an electronic switch in the ECM.
  2. There are no ECM tests mentioned in the VRSC EDMs (electrical diagnostic manuals). If the coil tests (various coil tests are explained in the EDM) are good, an ECM malfunction is then considered to be a likely cause.
  3. I don't know what you mean by this. Coil resistance tests can be performed either on or off the bike.
