Hmm, breather tubes, breather tubes, are you the culprit again? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 07-26-2018, 07:16 PM   #1
BerryNero
Registered Full
Feedback Score: 0 reviews
Hello from a total newb!
I salute all the members of this magnificent forum, which made me very broke and very happy by making me buy a used V-Rod.
Being a scooter user for 5 years, I took the plunge and bought a 2012 (10th anniversary) silver(Brilliant Silver Pearl!) color VRSCDX. I am a responsible driver so I'm planning to take lessons for a while to be able to control this humongous monster properly.
So, after spending some time on the training field, I've noticed a leak in the cylinder heads (please see the pictures attached) and as a typical panicked 2nd hand V-Rod owner, I looked at this forum to search for clues. Many threads point out to the fact that crankcase breather tubes under the air box are to be blamed.
But since I'm a total newbie, I have no idea what a crankcase is, let alone a breather tube. I'll go the dealer to have this checked, but any help before will be muchhhh appreciated.
As far as I understand, if it's not leaking, it is not a Harley but still wanted to ask:
- What might be the cause? Is it definitely the breather tubes?
- What is the name of that part that lets oil out called? (bottom jug?, rear cylinder?? cylinder head??? case????)
- Would the repair be expensive?
- Urgency of the situation (i.e. stop what you are doing and run to the repairman vs have it fixed before next summer)
thanks in advance!
peace out,
BN
ID:	529015   Click image for larger version
I'm a newb, bear with me until, well, I'm not.
BerryNero is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-27-2018, 08:43 AM   #2
stever975
Super Moderator
Images: 31
Feedback Score: 1 reviews
Quote:
Originally Posted by BerryNero View Post
...I've noticed a leak in the cylinder heads...
...Many threads point out to the fact that crankcase breather tubes under the air box are to be blamed.
The joint you say is 2 mm wide is between the cylinder head and the engine case (cylinder). That's where the cylinder gasket sits. A leak there would mean a blown gasket, loss of compression and contaminated coolant. Oil leaks don't usually show there. The oil is more likely migrating there from above and the breather tubes are the most likely source although the cam covers (the next joint up) can also leak oil.
The cost and urgency depend on what the actual source is. If it's the breather tube(s), cost is "low" and urgency depends on how you feel about the oil mess.
stever975 is offline   Reply With Quote
Old 07-27-2018, 03:35 PM   #3
BerryNero
Registered Full
Quote:
Legend! Thanks a lot, much appreciated.
Does that mean since there actually is an oil leak there, I might have a blown gasket? The bike runs pretty fine though, with proper power and everything, so I think I don't feel any loss of compression.
cheers,
BN
Old 07-27-2018, 05:46 PM   #4
tbird113
USMC Tanker
tbird113's Avatar
Feedback Score: 4 reviews
When my breather tubes leaked, oil was all over the engine. It looked like the whole engine was leaking.
Replace the breather tubes, check the o ring on the shell casing thingy & clean the engine then go for a ride. Check the oil level too
CFR exhaust, VMOD reduced reach black handlebar kit, Corbin seat, Cobra fi2000
tbird113 is offline   Reply With Quote
Old 07-27-2018, 07:43 PM   #5
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
can you find any oil above that mark say 2 inches above?? Feel all around the head and look at hand for oil locations
'06 street rod SuperCharged (and proud of it)
'46 Norton 16H w/SideCar
Tie_One_On is offline   Reply With Quote
Old 07-27-2018, 08:08 PM   #6
H-D Heathen
Asatruar
H-D Heathen's Avatar
Images: 29
Feedback Score: 6 reviews
My money's on it being the breather tube or o-ring .
And stay away from the dealership, most of them know less than you do about the Revolution motor. Do you really want them to learn on your bike?
Not everybody likes us, but we drive some folks wild..-Hank III
"Nothing is foolproof if you have a sufficiently motivated fool."
2006 VRSCR-"Not another black V Rod..." She's been beat on, thrown to the ground, abused,neglected & put away dirty..... but the gas gauge works !
"I find as I get older that I have less and less to say about more and more.I thought I was mellowing as I got older,turns out I just don’t give a shit.”
H-D Heathen is offline   Reply With Quote
Old 08-22-2018, 02:49 AM   #7
hedgehanter
Registered Full
Hi,
Oil leaking from the top end of the cylinder of my 2005 VRSCB (see pic below), not bad really but noticeable. Is there an easy way to fix (gasket replace with engine still in the bike) it or cannot be repaired without taking the engine off?
hedgehanter is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
