I have an 08 105th Anniversary VRSCAW. The only mod I have done was back in 09 when I put TAB non-baffled slip ons. I was told by Harley there was no need to remap, so I didn't. Just last week after filling up with Chevron 92 octane I started backfiring bad and stalling out immediately after backfires. Not sure what could cause this and am afraid to take to the dealer and pay a rediculous amount just to hook up to diagnostics. If you have experienced this or have any info please let me know. It could either be a remap problem or bad fuel, not sure.
Take a look a the tech section, and pull your codes. Let us know what codes you find.
Make sure you go through and check your BATTERY CABLES and your GROUND WIRES. There are two grounds. One to the front of the engine from the battery, and one from the rear of the engine to the frame. Check all those connections for tightness.
Running your bike with free flowing pipes, especially wide open pipes like the Tab's without re-mapping your bike is really not optimal. You probably have a massive stutter on the low end, that kind of smooths out when you get above 3500 RPM.
That, and you're probably running pretty lean at cruising speed, and idle.
The bikes run lean from the factory, as a matter of EPA regulations, and running free flowing after market pipes on a bike that's already lean, just compounds things.
Welcome to the forum and let us know what you find by pulling your codes.
take a sample of gasoline from your tank.Suck from the bottom of the tank where water and other debris will settle.put the sample in a clear glass container so you can see it good.
Was the tanker truck there filling the underground tanks? Never get gas if the truck is there. They stir up all the trash and water in the underground tanks when they're filling them.
Thanks everyone for your advise. RJRivero, it was the ground, must not of made sure it was tight when I put the new battery in. Thanks much, and will also get it to the dealer and get it re-mapped so i'm running the right fuel/air ratio so I don't encounter any more problems. I appreciate all your guys input.
You can put xieds in, that will cause it to run a little richer, I have them on mine I use tabs with baffles bike runs great.
Related Threads
Harley Davidson V-Rod Forum
2.7M posts
68.6K members
Since 2003
