Water/ meth injection - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD Big Bore/Turbo/SC/NOS area
Reply
Thread Tools Display Modes
Old 03-03-2018, 02:39 PM   #1
swampboogiedoug
Registered Full
swampboogiedoug's Avatar
Feedback Score: 11 reviews
How many of you would be interested in a kit ? I've researched this. Injectors now can atomize to under 10 microns at 3-5 bar pressure. (Old design car kits could maybe get down to 20 microns but needed 100 pounds & up pressure to achieve that). Better technology means we can use smaller pumps & have better results. Idea is to run them as on or off to eliminate controller, but the flow pretty much matches demand requirements based on load. Looks like price would come in between $250 - 300. Might have to fabricate a few brackets to mount pump & tank. Please let me know of interest, we'll get a better price on the pump for more units. Primarily for boosted applications but NA can benefit too. Thx
swampboogiedoug is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-03-2018, 06:28 PM   #2
Rapidone
Registered Full
Rapidone's Avatar
Feedback Score: 0 reviews
Quote:
I would be interested in more information on this.
Rapidone is offline   Reply With Quote
Old 04-03-2018, 12:14 PM   #3
ManicMechanic
Registered Full
What conditions are you running under that you feel the need for water injection?
ManicMechanic is offline   Reply With Quote
Old 04-04-2018, 03:40 AM   #4
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
Feedback Score: 1 reviews
Do you have a technical file and data sheets?
And how do you plan to achieve that with on/off only?
Hog of Steel
Jan-Dirk is offline   Reply With Quote
Old 04-04-2018, 01:21 PM   #5
swampboogiedoug
Registered Full
Manic, Most of us with forced induction still use the stock CR. This helps to cool the intake charge & reduce knock. Can assist racers too.
Jan Dirk Would like to use a variable controller but cost & application specific unit seems to be hard to find. Most car stuff is on/off. We use a Hobbs switch ( pressure activated & adjustable for boost level) that turns the unit on. you want the most flow under highest acceleration load which is a lower rpm when boost is coming on & tapers at higher rpm.
Would appreciate any suggestions !
Old 04-04-2018, 01:43 PM   #6
ManicMechanic
Registered Full
If you're boosted that makes more sense. Your first post came across as "hey wouldn't it be cool" but for no real reason.
I've worked with water injection on old airplanes and a few cars and WI is intended to make up for the missing cooling effects of lean mixtures. Most often though WI is just a crutch for an imbalanced engine.
If there is a demand for an inexpensive controller I might know someone willing and able to build one.
Old 04-05-2018, 11:18 AM   #7
swampboogiedoug
Registered Full
I agree on what it used to be. Tech has advanced to where its now viable to increase turbo efficiency & lower IAT's substantially. It is OEM on some of the new BMW turbo models.
An inexpensive controller would be fantastic, can't determine interest from lack of posts.
Old 04-06-2018, 02:19 AM   #8
mdomicolo
Registered Full
Pair this on the boosted bikes, i'm sure it would be fantastic!
mdomicolo is offline   Reply With Quote
Old 04-06-2018, 03:34 AM   #9
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
https://www.snowperformance.eu/en/wa...turbo-gasoline
btw I will not install a waes on my bike, it requires too much attention and it is prone to fail. And when it fails you have a problem because you will realize it only when it's too late.
water injection is not meant for every day riding
Hog of Steel
Old 04-06-2018, 12:56 PM   #10
swampboogiedoug
Registered Full
Jan That's why we're on the Forum, to build one that won't fail & works on the turbo Vrod !
Old 09-10-2019, 02:56 PM   #11
Rapidone
Registered Full
Rapidone's Avatar
Did this idea go anywhere?
Old 09-10-2019, 04:43 PM   #12
rbabos
Registered User
I think it died, or at least it should. Keep it simple and avoid it on a daily rider.
rbabos is offline   Reply With Quote
Old 09-11-2019, 11:19 AM   #13
swampboogiedoug
Registered Full
Problem was a controller and suitable pump. For atomization you need a high pressure ( 100 psi?) pump, controller should be boost referenced, not sure how to regulate flow, thats why I put this on the Forum, how do we accomplish that ? Idea was to use it to cool inlet temperature to reduce knock & increase motor air density. Doing the math a quart would last quite awhile if its only sprayed at say 6 psi or greater. All of the car stuff is repurposed agriculture or fountain application parts. Who can suggest parts to make this work ?
Old 09-17-2019, 06:02 AM   #14
Jan-Dirk
Autobanmod
Jan-Dirk's Avatar
Images: 367
Garage
https://www.turbozentrum.de/Boost-Co...tage-2-MAF-18T
Hog of Steel
Old 09-17-2019, 01:09 PM   #15
swampboogiedoug
Registered Full
The idea is great, just the pump is a repurposed agriculture unit & the tank is designed for auto use ( too big for a bike) IMO.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum
Yamaha Motorcycles Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
BMW Scrambler Forum Ducati Scrambler Forum
