Has anybody tried the Wilbers lowered VRSR suspension? - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > Specific Model > VRSCR
Reply
Thread Tools Display Modes
Old 07-06-2018, 02:09 AM   #1
dralex
Registered Full
Feedback Score: 0 reviews
I want to lower my VRSCR a bit.
I have done some research and the Hyperpro fork springs will lower the front by about .75 inch. I can get YSS shorter shocks for the back. I was thinking 15 inch so the bike is lowered front and back by .75 inch.
But I also found some Wilbers shocks and fork springs that will lower the bike by 2 inches. This setup will cost double the price of the Hyperpro/YSS. The main difference is in the rear shocks, the front springs cost the same. So I could possibly get a front Wilbers lowered by 2 inch and some 14.5 inch YSS rears.
Has anyone tried them?
And unfortunately Works Performance and Dave Quinn have closed shop so I can't get custom made shocks from them.
dralex is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-06-2018, 09:59 AM   #2
streetrodracer
Lifetime Premium
Leave the stock suspension alone - just buy shoes with a 1" thicker sole ! If anyone could use the higher longer travel R suspension I would think it would be you all down under. Also for shorter rear shocks check bottomed length so swing arm does not hit the bottom of the fuel cell - just back off rear shock preload to 0 and fork spring spacers could be cut to lower, I personally wouldn't do either but that's much less expensive and can be reversed easily.
streetrodracer is offline   Reply With Quote
Old 07-06-2018, 08:18 PM   #3
DMS1970
Registered Full
I put a 1” lowering link on my bike. Now it sits level and it is night and day different for putting my feet on the ground. No issues with bottoming out the gas tank, even riding with a passenger. I highly recommend it.
DMS1970 is offline   Reply With Quote
Old 07-06-2018, 08:53 PM   #4
DMS1970
Registered Full
[/IMG]
[IMG][/IMG]
Old 07-07-2018, 09:31 AM   #5
streetrodracer
Lifetime Premium
That looks good DMS1970 you could also slide the forks up in the triple clamps a half inch or more since your fork reflectors have been removed. ( There's plenty of unused room in the upper triple clamp for them to slide up into ) This would help maintain the front to back balance and closer to original geometry of the bike. Watch for fender and tire clearance at full bottomed out. I relocated the pax footpegs to the swing arm and removed those gyno position heavy brackets and pegs so anyone that's done that can't lower it unless they add bumper stops to the shock shafts because the peg brackets will hit the fuel tank. I ground off the brackets for clearance but my final fix is to get 16" custom shocks and even fully bottomed out no contact.
Old 07-07-2018, 10:12 AM   #6
Tie_One_On
Tie One On
Tie_One_On's Avatar
Images: 11
Feedback Score: 4 reviews
move the forks up in the triple tree a little instead of removing travel length from the suspension
'06 street rod SuperCharged (and proud of it)
'46 Norton 16H w/SideCar
Tie_One_On is offline   Reply With Quote
Old 07-13-2018, 05:34 PM   #7
Hogpro
www.hogpro.com
Hogpro's Avatar
Images: 5
Feedback Score: 5 reviews
I just had these Works shocks built to my specs at 15.5". Works is slowly building up their business again so contact them I am sure they can build what you want since they just finished these last week.
ID:	528863   Click image for larger version
HOGPRO
Custom Widetire Kits and Wheels
Hogpro is offline   Reply With Quote
Old 07-14-2018, 12:49 PM   #8
dimebag
Registered Full
+1 for Works.
have a set on my R and love them.
dimebag is offline   Reply With Quote
Old 07-21-2018, 09:03 AM   #9
boostinbaja
Bad ride inside
boostinbaja's Avatar
Images: 10
I slid my fronts up and then did a 240 in the rear using a 2012 DX swingarm with stock rear shocks, Dropped the height 2 inches or so. I ride fast, the difference in handling is awesome!
vivid black "R"
resurrected by J3dogs and crew
screaming eagle cnc heads
SE stage 2 cams
SEPT
26tooth
V+H 2-1
131 rwhp
240 pirelli fat ass
lots of powder coating
wicked airbox
and other stuff
boostinbaja is offline   Reply With Quote
Old 08-11-2018, 01:28 PM   #10
RF_R_US
Lifetime Premium
RF_R_US's Avatar
Images: 35
Feedback Score: 1 reviews
I slid my forks up 1/2" in the triple tree and put on Works Suspension -1/2" custom shocks. I was concerned about hitting the gas tank with the swingarm, but no problem and it lowered it just enough as I wanted.
YMMV,
John
RF_R_US aka John
"D" headlight, Kuryakan LED mirrors, Heavycycles Stage II Tail Light, Rinehart 2:1, Works Custom 15.25" Shocks, Racetech Forks (best investment $$$ can buy), Wicked Airbox, Thundermax
(now I can REALLY screw up this bike), etc., etc.
Other Fossil Fuel Burning Toys: '05 FLHTCUI, '96 KLR650, '73 Chevy Nova SS yeah it's :bad:
RF_R_US is offline   Reply With Quote
Old 04-13-2019, 01:50 AM   #11
Biggsy
Registered Full
Quote:
What rear fender is this?
Biggsy is offline   Reply With Quote
Old 07-09-2019, 03:44 PM   #12
mitch2000
Registered Full
mitch2000's Avatar
Images: 15
I have Wilbers on the rear (plus Wilbers inserts upfront) but standard length, so doesn't really help in your question, but I can confirm that they are brilliant, and the quality is superb, if thats of any help.
mitch2000 is offline   Reply With Quote
Old 07-09-2019, 04:56 PM   #13
ozzie21
Registered Full
Legends Air Suspension
I had Legends Air Suspension on my Muscle. You can see more on that with pics at my posts on this forum. Never had any problems. You can raise or lower bike as you like and also depending on load, whether you're riding solo or with a passenger.
ozzie21 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
