Big end gone rear cylinder front cylinder tight - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 04-14-2019, 07:17 AM   #1
Calais08
Registered Full
Feedback Score: 0 reviews
2015 vrod muscle tts supercharger low comp pistons 2nd disaster in 1000miles mechanic put 2nd hand crank in and rods now the bearings are gone 15k later and no help from mechanic .... any1 got any no how on how I can make this motor last 3rd time lucky with another tuner obviously cheers
Calais08 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-14-2019, 08:32 AM   #2
rbabos
Registered Full
Feedback Score: 1 reviews
Quote:
Well, for one you should have an oil pressure gauge on it to know what's going on. I even have one on my stock bike. Second the tune is probably crap.
rbabos is offline   Reply With Quote
Old 04-14-2019, 08:54 AM   #3
Knut J
VRSC est -03
Knut J's Avatar
Time to call pro`s: http://www.vreelandsharley.com/v-rod-racing
WILL RACE FOR FOOD!
Knut J is offline   Reply With Quote
Old 04-14-2019, 08:45 PM   #4
mattssi
Registered Full
Feedback Score: 3 reviews
Which tuner were you using anyway? TTS provides Power Commander V base map that should at least get you in the ballpark.
2011 DX w/ Goodies
mattssi is offline   Reply With Quote
Old 04-15-2019, 07:34 PM   #5
shaunm4639
Registered Full
Vreelands website puts a bulge in my pants!
shaunm4639 is offline   Reply With Quote
Old 04-16-2019, 02:53 AM   #6
Calais08
Registered Full
Yea I have pcv-turbo got pistons from vreelands just got a dickhead mechanic who put 2nd hand rods and crank in my bike can you tell by the numbers on crank if it’s original crank ?
Old 04-16-2019, 08:46 AM   #7
rbabos
Registered Full
What difference does it make as long as the rods an crank are in spec? Now if he didn't measure, that's a different story as the clearances could have been off.
Old 04-16-2019, 08:44 PM   #8
BIG POPPA 66
Registered Full
could be a number of things he did wrong or complete shit tune you cannot run a bike motor with boost in without tuning it proper
BIG POPPA 66 is offline   Reply With Quote
Old 04-17-2019, 08:26 AM   #9
streetrodracer
Lifetime Premium
Build it right or build it again.
Yes, what Ron said about measurement is leading to this question - did he check the colors on the crank and fit bearings based on that or did he actually measure the clearances on the second hand crank in your cases and install bearings based on that ? What was the first disaster 1000 miles ago ? Are you saying you got 15K miles out of this build or that's the mileage on the bike ? Also did the mechanic install OEM bearings and did they spin in the case cutting off oil flow ? - if so you might want to get the coated bearings from Vreeland's and get them pinned in place on your next build, possibly stronger rods, studs and bolts and check the tune as BigPoppa, Mattssi and Ron said. This can be a problem with Big Bores too if not built right but especially with power adders strapped on a stock engine low end on the Turbo's and S/C'd - if not done right by building the engine strength up for the expected additional power output of 150 to 200 % you will find the weak spots - one by one - and it's very expensive.
streetrodracer is offline   Reply With Quote
Old 04-18-2019, 12:05 AM   #10
Calais08
Registered Full
Cheers , no 15k it cost me 11k then apparently bent crank rods and replaced with 2nd hand rods and crank and low comp , now bearings have gone and both had oil so mechanic is at fault
Old 04-18-2019, 12:07 AM   #11
Calais08
Registered Full
Either way he not paying for the rebuild can I get 10thou under bearings ?
Old 04-18-2019, 12:08 AM   #12
Calais08
Registered Full
11k then 3500k in second build so he ripped me 14500 and I got 1000 miles all up
Old 04-18-2019, 12:52 PM   #13
rbabos
Registered Full
Doesn't quite work that way with these engines. You need to mike the journals and see what color corresponds to the correct clearance based on those diameters. Those numbers are in the SM.
Old 04-18-2019, 08:51 PM   #14
Kamakiuga
Registered Full
Kamakiuga's Avatar
Arrow What kinds of HP Exhaust Systems can I put on my 2007 Harley Davidson Night Rod...
I need a list of High Performance Exhaust Systems that I can install on my Harley Davidson VRSCDX-V-Rod Night Rod Special. Liquid-cooled, 1130cc Revolution V-twin engine, 5 speed, 120HP, 85ft. Lbs @ 7000rpm.
I want it to be loud like a "Real Harley Davidson" sound when I go down the street, when I Rev the engine. Right now the stock exhaust is too silent, Not loud at all and it doesn't sound like a Real Harley Davidson. Its like it has a silencer exhaust pipes.
Can you guys help me out and list some High end High Performance Exhaust systems that I can install on my Night Rod that will make it sound like a Real Harley Davidson bike. It has to bolt right up..
thanks for your help guys! Awwwright! Spring is here and Summer is around the corner we are riding in the warm, hot and dry weather...
Mahalo!
Kamakiuga
Seattle, Washington
Name:	Kamakiuga Night Rod Special .jpg
ID:	532017   Click image for larger version
Name:	Kamakiuga Night Rod Special4.jpg
ID:	532019   Click image for larger version
Name:	Kamakuga Night Special 2.jpg
Kamakiuga is offline   Reply With Quote
Old 04-19-2019, 03:52 PM   #15
pecee
Registered Full
pecee's Avatar
Feedback Score: 4 reviews
most likely the motor wasnt cleaned of schrapnell from the previous detonation.crap in the oil gallerys .
pecee is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How tight is the rear seat with the HD backrest? 2Lane69 VRSCF 4 03-24-2014 06:38 PM
How tight is tight? gotvrod V-ROD General 9 04-02-2008 11:46 AM
Wego 02 rear sensor is TIGHT against cylinder, any danger here? Pics. spinedoc Daytona Twin Tec 64 01-31-2008 08:05 AM
B front end for R front end... cmptrgk Trading Post 2 01-15-2008 09:02 AM
