9mpg and glowing headers on PV tune..... - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Go Back   1130cc.com: The #1 Harley Davidson V-Rod Forum > V-ROD Discussions > V-ROD EFI
Old 04-06-2019, 10:31 AM   #1
Dracon
So I bought a used power vision from the board and got my license from Fuel Moto. They sent me a tune to match my bike with the license. My only mods are a K&N filter and Akrapovic exhaust - 2009 VRSCF.
I installed the exhaust and flashed the ecu yesterday and rode to work this morning - I noticed I was using a ton of fuel pretty quick, I started with a full tank and 36 miles later when I got to work I had less than 1/4 tank left. I also looked down on the interstate and the front header was glowing red. I’m assuming it’s burning the extra fuel in the pipe? No popping or other bad symptoms that I could tell. When I it off the interstate the pipe didn’t glow as much, but could still tell it was a little red right by the head.
I’ll call Fuel Moto Monday, but do you guys think I’m safe to ride home? And is there anything I can double check to make sure I didn’t do incorrectly?
Dracon is offline   Reply With Quote
Old 04-06-2019, 11:53 AM   #2
pfbmgd
pfbmgd's Avatar
36 miles and quarter tank doesn`t sound unusual . I get about 120 to 140 on tank . Plus who knows if your gauge is accurate .
2008 VRSCDXA
Thundermax
Rinehart 2-1
Topless
Avon tires
Progressive springs front
Progressive 444 rear
pfbmgd is offline   Reply With Quote
Old 04-06-2019, 12:32 PM   #3
Dracon
Sorry, I meant there was less than a quarter left in the tank - so I used over 3/4 of my tank in 36 miles. I had filled all the way up before I left.
Old 04-06-2019, 12:49 PM   #4
knight rod rob
knight rod rob's Avatar
glowing headers
Oh yeah u need to check the settings before u damage the engine. Thats way to much fuel, hell u might want to change the oil once u get it straight. I understood your first post and u are right to call moto. I would not ride it far again until I know problem is solved.
knight rod rob is online now   Reply With Quote
Old 04-06-2019, 02:21 PM   #5
NexVision
Reflash the original tune and see if it runs any better.
Sent from my SM-G975U1 using Tapatalk
011 Night Rod Special VRSCDX
NexVision is offline   Reply With Quote
Old 04-06-2019, 02:40 PM   #6
pfbmgd
pfbmgd's Avatar
Sorry read it wrong . Get it cheeked and like a poster mentioned check your oil . I would not ride it .
2008 VRSCDXA
Thundermax
Rinehart 2-1
Topless
Avon tires
Old 04-06-2019, 02:48 PM   #7
I agree with stock cal reload as a test. PV cals are not rich by no means. Actually lean in spots until tuned some.
Old 04-06-2019, 04:07 PM   #8
Dracon
My wife’s bringing the PV up to my work and I’m going to flash the original and see how it does on the way home... thanks for the suggestions
Old 04-06-2019, 06:07 PM   #9
dimebag
Agreed riding would be a very bad decision.
Tow the thing home before you fry your motor
dimebag is offline   Reply With Quote
Old 04-12-2019, 04:22 AM   #10
Only 9MM
Only 9MM's Avatar
Well? The rest of the story.................
Current Bikes
2017 Street Glide Special
2009 FXSTSSE3 Softail Springer CVO Screaming Eagle
2014 VRSCDX Night Rod Special Vivid Black
Past Bikes
2007 Thunder Mountain W/ 103" Screaming Eagle
2007 VRSCDX
2008 Nightster
2009 Softail Custom
2010 Softail Convertible CVO Screaming Eagle
2010 Nightster
2014 Softail Slim
Only 9MM is offline   Reply With Quote
Old 04-12-2019, 07:23 AM   #11
Dracon
I need to finish testing, but here’s where it is now. I flashed the original tune on it in the parking garage at work - when I turned the ignition on to do it, my gas gauge went up to just over half a tank. The gauge had been wonky when I got it, but I let seafoam sit in a full tank for awhile and it had been working fine for months. After the reflash the ecu resets and it went to almost 3/4 of a tank.
I checked the oil and it was fine, and I had been reading all day about the glowing pipes and it went back and forth on people saying that with a thinner single wall pipe on the Akrapovic it was normal, and others saying it wasn’t - but none of them had the Akrapovic pipe. Since I was on the original tune, I started it and let it idle and since it was dark I could start to see the pipes near the head looking red when it got hot. I rode extremely easy next door and filled up the tank and then rode back to the gas station by my house and filled up again to see how much gas I had used - 0.9 gallons in 36 miles so I know on the stock tune I’m not dumping fuel.
I want to test the same thing on the tune from Fuel Moto, but first I want the PV mounted so I can set the digital gauge function to display my engine and coolant temps, real time mpg, etc. So since then I’ve been making a mount for the PV, flipping my mirrors to under the bars instead of above since I had the front panels off, and making a new bracket so I can use my windshield with my headlight cowl on.
I should be done with all that stuff today, but it’s raining here the next couple days so I won’t be able to test it right away.
Old 05-25-2019, 07:16 AM   #12
monstah89
monstah89's Avatar
Was there any fixing it ? I have the same problem with the same exhaust. I just spent the money on the PV an the target tune but they have not sent me an email yet. My exhaust glows cherry red an piss poor fuel.
monstah89 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
PV Quick Tune & Decel Popping Magoo40 PowerVision 9 07-14-2017 03:46 AM
Power Vision PV-1: How Often Do You Tune? Jay_Rod V-ROD EFI 0 12-31-2014 12:14 PM
Dealer botched PV tune? 9sec240 V-ROD EFI 17 03-27-2014 01:29 PM
temp ranges for pv auto tune nightrodder47 V-ROD EFI 2 09-22-2013 03:02 PM
Headers glowing red with new maps HM08vrscdx PowerCommander (All Versions) 8 07-28-2009 07:59 PM
