Clutch replacement - 1130cc.com: The #1 Harley Davidson V-Rod Forum
Old 01-04-2020, 07:10 PM   #1
Bfish51
Clutch replacement
Hello all, I have a 2007 night rod, I bought about two weeks ago and started having clutch issues so I flushed the system and still same result, when I flushed it the fluid was pretty bad, looked like coffee with French Vanilla creamer. So I ordered new friction plates and steel drive plates, I got the everything off and swapped out, now I am at a stand still with the center nut. (Used air impact to get it off) I inspected the nut and everything is good to go (manual suggests replacing it). I don’t want to impact it on because i want to get it to the tight torque spec (162ftlbs) but I do not have the specialty tool nor can I think of any ideas on how to stop the basket from moving once I start put the nut on. Any ideas?
Brett
Bfish51 is offline   Reply With Quote
Old 01-04-2020, 07:29 PM   #2
You could pop the oil pump off and use a Johnson bar in the square drive.
Old 01-04-2020, 07:43 PM   #3
try renting a torque wrench from your local tool rental place.
To keep it from rotating put the bike in 4-5 gear and have someone stand on the rear brake. Worked for me.
I torqued mine to 150 lbs because that is as high as my wrench would go. Then gave it another shot.
Old 01-09-2020, 06:33 PM   #4
Shovel Convert
You could try an impact w/ a 160 ft lb torque stick. No guarantees here.
Shovel Convert is offline   Reply With Quote
Old 01-09-2020, 06:40 PM   #5
MY_VRSCDX
matt blk & fire hot
MY_VRSCDX's Avatar
Images: 38
Exclamation SE basket time
Most likely your clutch basket Springs on the backside are shot!
I had a bad chatter taking off from a stop mostly when it was cold and I just started to ride. Turned out the stock clutch baskets have a really crappy designed to hold the torque springs in. It's hard to see but they ware deep grooves in the aluminum. I installed an SE basket that has anodized aluminum to strengthen it, and allow for less wear and tear at the Springs. It cured all of my clutch problems. At a minimum I would at least install a stock clutch basket before you close it up.
The older I get, the better I was
Run'in on Empty, but the F'in gauge doesn’t work, so I probably have 1/2 a tank!
MY_VRSCDX is offline   Reply With Quote
Old 01-09-2020, 06:41 PM   #6
Good Idea. Those things are likely as accurate as most torque wrenches.
Old 01-09-2020, 10:46 PM   #7
Ceigenberger
Ceigenberger's Avatar
Be careful with a torque stick. Those are really just a torsion spring, and a good impact puts out 450 ft/lb and can easily overpower the stick.
Ceigenberger is online now   Reply With Quote
