Torque specs - 1130cc.com: The #1 Harley Davidson V-Rod Forum
» Sponsors
Reply
Thread Tools Display Modes
Old 04-17-2008, 05:49 PM   #1
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Feedback Score: 18 reviews
Torque specs
I'm doing some work on a friends 08 DX. What are the torque specs for the rear axel, front axel and fork tube nuts?
Vrod-Mike is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-17-2008, 06:03 PM   #2
vroddrew
Tired of the crap
vroddrew's Avatar
Images: 15
Feedback Score: 0 reviews
Rear axle nut - 140/150 ft/lbs
Front Axle Nut 50/55 ft/lbs
Fork Tube Nut (at the top of each shock) - 16/43 ft/lbs
Fork pinch Bolts 31/34 ft/lbs.
vroddrew is offline   Reply With Quote
Old 04-17-2008, 07:17 PM   #3
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Thanks Drew, but 16/43 for the fork tubes? Seems like quite a spread.
Old 04-18-2008, 02:08 PM   #4
stever975
Super Moderator
Images: 22
Feedback Score: 1 reviews
Quote:
The 16 to 43 ft·lb numbers are correct. It's an o-ring seal so torque value isn't critical. Tight enough not to come loose but don't exceed 43 ft·lbs.
stever975 is offline   Reply With Quote
Old 04-18-2008, 02:21 PM   #5
Ed-Rod
Registered Full
Ed-Rod's Avatar
Careful with the fork tube nuts if you are taking them off. Big spring under there.
2004 B 1350 Stroker
Done gone big bore
VRFID
Supertrapp V5
Jones 480/455
SE CNC Heads
2010 Dragon Rally Alumni
Ed-Rod is offline   Reply With Quote
Old 04-18-2008, 07:12 PM   #6
vroddrew
Tired of the crap
vroddrew's Avatar
Images: 15
Double checked the form tube cap - accurate. Obviously, just get it decently tight and you'll be fine
Old 04-18-2008, 07:14 PM   #7
vroddrew
Tired of the crap
vroddrew's Avatar
Images: 15
Quote:
Like this?
Old 04-18-2008, 07:16 PM   #8
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Okay thanks guys. I just wanted to make sure.
Old 04-18-2008, 08:33 PM   #9
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
What's the torque specs for the rear rotor bolts? I found out the hard way that the caliper won't slide off without removing the rotor.
Old 04-19-2008, 05:39 AM   #10
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Anybody know the rotor bolt torques specs???
Old 04-19-2008, 05:54 AM   #11
vroddrew
Tired of the crap
vroddrew's Avatar
Images: 15
Rear brake disc is 30-38 ft/lbs.
I've had the rear wheel off a few times, as well as the calipers. Never had to remove the brake disc from the wheel to do this. You should be able to rotate the caliper up and out of the way.
Old 04-19-2008, 06:39 AM   #12
CJR
Registered Full
CJR's Avatar
Images: 3
I think in the tech section I saw all the torque specs for the whole bike listed you can print and save them. Look around the site or do a search and it will come up.
CJR
CJR is offline   Reply With Quote
Old 04-19-2008, 09:07 AM   #13
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Thanks Drew. On my 03 I can get the caliper off without removing the rotor, but with the Brembo caliper I couldn't get it off without removing the rotor.
Old 04-24-2008, 06:43 PM   #14
Vrod-Mike
Chrome is king!!!
Vrod-Mike's Avatar
Images: 314
Anyone have the torque value for the caliper mounting bolts and the handlebar riser bolts?
Old 04-27-2008, 01:15 PM   #15
tonysalter
Registered User
Looking for the torque spec for the velocity stack to airbox screws, the ones that bolt everything the the intake.
tonysalter is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
